Small Wire Back of Alternator
Old Jan 22, 2019 | 09:07 PM
DGS's Avatar
DGS
Question Small Wire Back of Alternator
I searched multiple forums but could not find a similar issue and an answer.
The issue is on a 1985 300ZX na, manual, with A/C.
The alternator was replaced a few years ago.
I found a single small (16 gauge) hanging wire, coming from back of alternator from one of the post connector.
It is a single small yellow (or light brown) coming from back of alternator, then goes into a single type connector casing, then the hanging end of the wire is black.
I posted a few pictures to show what I am looking at.
The FSM does not show or refer to that wire at all; I attached a picture of the page 24 of the FSM.
Does anyone know where that small wire is supposed to connect to?
Could it be a wire for a condenser that should be bolted to the back of the alternator to keep static out of the radio?
If yes, where and what type of condenser to buy?
Where to get that Condenser Noise Filter Suppressor for the alternator?
Any help would be appreciated.
Thanks in advance.
Old Jan 27, 2019 | 06:17 PM
DGS's Avatar
DGS
To help other members here is the information I collected from research and help in a different forum:
The hanging wire with the female bullet terminal is connected to the cable that screws onto a circuit bolt (10 mm copper nut).
A member informed me that there is a condenser shown in the circuit diagrams on both the digital dash and analog (needles) dash of the "1985 300ZX Factory Service Manual", with the wire of the condenser attached to the wire (or alternator circuit bolt if it is not a plug/socket connection) that goes from the alternator to the fusible link. No reason it can't be a generic condenser for ignition. The capacitor is fairly forgiving as long as it's rated for 12VDC or up, which any from an auto parts store will be.
A larger condenser will be capable or providing more noise suppression but if too large just takes up extra space.
Up to now I was not able to find a local car part store selling a condenser / capacitor.
Hope this helps if someone else has a related question.
Old Feb 1, 2019 | 07:28 AM
86tcoupe's Avatar
Sure looks white , I think thats a radio amp wire
maybe from a high output audio z31's had ...body sonic system had a lead lke that
the noise supp. Were tiny 18 guage wires, thats 12 or 10 guage and mounted to the alt .
the crazy amp draw in the crazy audio sustems ,is the only reason to have a lead off the alt , you would fry /blow the fuse , not the elect system
Old Feb 2, 2019 | 08:26 PM
DGS's Avatar
DGS
Screenshot of the circuit diagram
Thanks. It makes sense.
The following is shown in the circuit diagram:
300aZphX
Jul 9, 2015 11:39 PM
Heat Rave R
Jul 20, 2010 12:00 AM
Jason C.
Jul 26, 2006 08:26 PM
DoTheDrew888
Aug 26, 2004 08:35 AM
