Rookie, need help
Old Oct 13, 2017 | 03:57 PM
GMan4030's Avatar
Rookie, need help
so this is going to sound like I'm an idiot but I'm really just new to all of this.
when i went to change the valve cover gaskets i took the distributor out and did not properly put it back it took me a while to realize this but when i did and set the car to TDC it would start and then rapidly decline in RPM and die however two teeth after TDC i can get the car to start if the distributor is turned all the way to the left but if i don't center it shortly after starting it, it dies it is also burning rich at first. any idea where i need to go with this?
Old Oct 14, 2017 | 08:41 AM
86tcoupe's Avatar
Have you tried 1 tooth , as it sounds like it would do it you need it turned back opposite from the direction you turned the base to get it running , check with a timing lite to see where it is will help
Old Oct 14, 2017 | 08:45 AM
GMan4030's Avatar
I did try one tooth but with multiple distributor positions it was no different, and it’s difficult to get the light on it to test
Old Oct 14, 2017 | 05:12 PM
GMan4030's Avatar
ok update, tooth one only works if the car is up to temp I've run it a few times today so ill wait until late tomorrow afternoon to try starting it in this position, thanks for the reply
Old Oct 15, 2017 | 03:20 PM
zxguy1986's Avatar
XenonZcar.com Z31 1984-1989 300zx Reference has your factory service manual. Maybe could help you out there
Old Oct 15, 2017 | 04:36 PM
86tcoupe's Avatar
Yeah the timing marks are hard if not impos. I think I set it to TDC off and made my own paint marks on down ,that would help
Old Oct 16, 2017 | 01:48 PM
Virtuoso's Avatar
Cool
The FSM is The Bible....have a hard copy here..(cost in 1997 = $60.00)....a mechanic told me people had to go to school to learn how to use it properly.
Doesn't matter; U CAN DO THIS!!
2jratz
May 4, 2017 12:57 PM
legalian
Apr 12, 2004 06:12 PM
kewlcat187
Sep 20, 2002 01:03 AM
Alienx66
Aug 16, 2002 03:41 AM
nissianimport420
Nov 7, 2001 12:43 PM
