Air vents only work in cold weather
Old Oct 18, 2017 | 11:27 AM
The85NA's Avatar
Angry Air vents only work in cold weather
Ok i own an 85 Na model with the auto climate. The system is being very odd and air only comes out the regular vents when it is colder outside(65°f or below). It seems if the temp outside is hotter than that hot air will proceed to blast thru the defrost vents which seems common in these cars. Any advice why this weird situation would be happening would help a ton! Thanks!
Old Oct 20, 2017 | 06:22 AM
86tcoupe's Avatar
why build a simple easy fixable proven system when you can build a complex , bit experimental , high # part cluster f=÷k ... lol
check the vacuum lines ,
vac switcheroo valve ,stuck actuator , power to them a stuck door itself , no heat if the temp is below ,55? The hc coolant needs to come up for the blower to operate, the blend door has a stout return spring so it takes everything , in top shape ,etc...etc
luvatenor
May 30, 2014 11:23 AM
swlabr
Feb 7, 2014 06:59 PM
gbpxl
Feb 19, 2013 06:06 AM
Pipsqueak
Jan 12, 2013 08:02 PM
brownjack
Aug 18, 2002 11:23 PM
