Rocker arm and lifters
Old Apr 2, 2018 | 10:22 AM
Chez's Avatar
Need some input from the experts. ...I habe a 1984 300zx turbo z31 50th Anniversary Edition and I recently removed the valve covers, removed the rocker arms and lifters to give them a thorough cleaning....now I'm in the process of putting everything back and I have a couple of concerns....do I ned to gap the valve stem seal to the rocker arm? I understand there is an intake side (top) and exhaust side (bottom)...the FSM does not say anything on re installing...What is the torque for the retaining bolts? The FSM is not very clear on installation.....any help would be greatly appreciated.
Chez
Old Apr 4, 2018 | 08:56 AM
86tcoupe's Avatar
Chez
Gap them to the valve stem seal? Think you mean to the valve ....no they are hydraulic
​​​​​​​usually have to look at the specs section on torque , you pulled the cam stands ?
Old Apr 4, 2018 | 10:06 AM
Chez's Avatar
No....I did not pull the cam....I bled the lifters individually for oil, lubed them and the camshaft and installed them. Getting ready to re install the rocker arms.
Chez
immortal557
May 27, 2012 02:17 PM
jmmorriso
Jul 30, 2006 08:37 PM
Airpilot16
May 17, 2003 05:19 PM
thomas schuchat
Apr 17, 2003 11:26 AM
