Relays (noob question)
Old Aug 24, 2007 | 07:09 PM
aratheff's Avatar
Does someone have a charts that shows which relay should be where? The description is gone off my relay cover.
Old Aug 24, 2007 | 08:44 PM
inqui-Z-tor's Avatar
Old Aug 25, 2007 | 11:27 AM
aratheff's Avatar
Thank you very much!
Old Aug 25, 2007 | 11:31 AM
aratheff's Avatar
So If missing some
What issue might I have I was missing the Vacuum pump, A/T, and Inhibit relays?
Old Aug 25, 2007 | 02:43 PM
Is the car an auto or 5 speed? And you really need to invest in a Haynes / service manual.
Old Aug 25, 2007 | 11:25 PM
aratheff's Avatar
5 Speed non turbo. Just ordered the manual.
Old Aug 27, 2007 | 01:14 PM
Originally Posted by aratheff
5 Speed
There's your reason why...
Old Sep 21, 2007 | 06:04 AM
ziklag1257's Avatar
Passenger headlight problem
I've been searching these forums for days and cannot find the answer I'm looking for.
1989 300zx non-turbo 5sp.
The passenger headlight does not work on HIGH BEAMS. Tried a new bulb, but the wire is not getting power for the high beam circuit...only on the passenger side. I have considered running a wire (as so many have suggested to others) from the driver side, but would prefer to do this correctly.
MANY of you have referenced a "HEADLAMP" relay. I cannot find it in my FSM. It's referenced many times in schematics, but I do not know the PHYSICAL location of the relay. The relay diagram posted does not show a HEADLAMP relay, with the exception of it being noted on the THEFT relay. The posted diagram also does not show a FUEL PUMP relay.
Is there another location for other relays? Can someone please help? Could it be the headlamp relay (if there is one), or possibly the headlamp sensor?
Old Sep 21, 2007 | 11:13 PM
my86z's Avatar
It's your headlamp switch. And it has been covered many times. But, it's normally on the low beam contacts (since they're normally used far more than the high beams).
ch33z3x
Mar 17, 2014 12:42 PM
ttxz003
Nov 8, 2012 03:10 PM
kyle_wise07
Jul 22, 2011 04:05 PM
skupy
Jan 30, 2005 01:56 PM
BartKnox
Apr 6, 2003 02:42 PM
