Oil Pressure High?
Old Jun 15, 2001 | 09:38 AM
Spot's Avatar
Re: Oil Pressure High?
usually a bad oil pressure sending unit will just read wrong. The car won't run any differently, the computer is for the fuel injection system. On both turbo and non 84-86's, it's located on the pass side, next to the oil filter (standing on the pass side, looking at the oil filter, it's to the left of it). If you have a Haynes manual, look on page 65, its item 6 in the picture.
From my '86 factory manual, here's the instructions to do an oil pressure check.
1. warm up engine.
2. stop engine and remove oil pressure switch.
3. install pressure gauge with sealant.
4. start engine and check oil pressure with engine running under no-load.
with rpms at:
1200 pressure should read 28
2000 pressure should read 43
4000 pressure should read 57
oil pressure at idling should be more than 11 psi
this test was with 10w-30 oil and oil temp between 77 & 83 Celuis. slight difference will be found because of oil viscosity or oil temperature. if difference is extreme, check oil pass and oil pump for oil leaks.
arte
Aug 30, 2015 09:54 PM
Eric9006
Oct 3, 2014 12:27 PM
zxguy1986
13
Apr 1, 2014 07:51 PM
Rupe
Jul 16, 2011 09:43 PM
serg92
Oct 10, 2002 03:09 AM
