new owner with 2 questions HELP!!
hey guys,
i just bought and 88 300zx and i have a big problem. my doors won't lock. i mean they physically won't lock. the lock button won't move. what could it be. i'm gonna take the doors apart tomorrow to try to fix it. any suggestions? thanks
also my second question(may be a ver stupid question) is it possible to put the 2+2 back seats in the non 2+2?
Originally Posted by SpeciallySpiked
Yeah, to point it out with more explanation, the 2 seater is shorter in length and height (in the back) than the 2+2 so... no
as far as door locks go is there anything that could be causing this?
Originally Posted by rocafellavc
so i know pretty much nothing about this car or anything but honda and mazda.
I just fixed this on a friends Z31. the latch mech was rusted solid. I tried to clean and lube it but ended up replacing with another one i had laying around.
http://www.xenonz31.com/6B10.html
Fiche Diagram
Fiche Diagram
the door issue was just extreme rust. i got it fixed. also took it to a shop to get checked out. and need quite a bit of engine work and what not. my exhaust is rusted all the way back to the cat. so i need a new exhaust. needs a tune up which i'll do myself when get money to buy the plugs wires and cap. also a problem that i need fixed now is that my e brake doesn't work? i can pull it up all the way but it doesn't pull the break. could this just be a cable?
That little lip can be removed with taking out a few screws! But like someone said before the 2+2 is a whopping 14 inches longer. if you look at a picture or at a 2+2 you can physically see the diffrance in the back.
