My lights still dont work..
Old Apr 4, 2009 | 11:03 AM
MistaZ31Turbo's Avatar
Ok people, here it is a month and change since I have owned this car and I have finally got her to fire up after wiring the fuel pump straight to the battery. (Kinda sucks have speaker wire everywhere). The problem is none of of my lights still work. I have checked fuses and relays and all of them have between 12.2 to 12.4 volts going to them. I just came across the headlight sensor and there is 12v going to the sensor but I dont know if its good or bad. I found the headlight timer and dont know what the hell its purpose is or what it does. I just cant understand how none of these lights are working when not all the light are running on the same harness. If I cant find the issue then Im going to have to rewire the headlights, taillights, turn signals, and electric fan using switches which will make my car look like a NASCAR plus its a lot of work to do. Sorry for the long post but im fresh out of ideas on what to check next. Anyone got any?
Old Apr 6, 2009 | 04:36 PM
Sigh...geez ok can someone maybe tell me why my headlights continually goes up and down when I hit just the headlight switch? The uphold relay is good. If your reading these issues, dont be scared to share knowledge.
Old Apr 7, 2009 | 03:11 PM
Sweets's Avatar
Usedta be Justin260z
Did you check the fuseable link in the engine bay?
Old Apr 13, 2009 | 07:19 PM
Everyone of them...they are all good
Old Apr 14, 2009 | 07:24 PM
reddzx's Avatar
Check out these links
http://www.300zxclub.com/showthread.php?t=78000
http://www.zeeyalater.net/comprob1.htm#head%20lights
Download a free factory service manual and follow directions. Go to www.z31.com and search for headlight switch repair.
http://www.xenonz31.com/reference.html
Old May 3, 2009 | 05:20 PM
mrbillishome's Avatar
I have a good one. For the last two weeks whenever i turn my lights on the only thing that comes on is the headlights. No guage lights, no tails, no markers, etc nada. My Brake lights work when the pedal is depressed and my reverse lights work, and blinkers do too. So do you think it is just the switch bc fuses are good.
Old May 4, 2009 | 06:10 AM
reddzx's Avatar
It's the switch. Everything goes through the switch. follow the links I posted above.
sneak
Oct 27, 2012 08:42 PM
Johnson0928
Aug 27, 2011 06:11 PM
Trevor280z
Sep 4, 2003 10:37 AM
(( Gio-Spot ))
Jun 1, 2003 10:46 PM
Creator
Aug 5, 2002 12:45 PM
