me again
Old Nov 20, 2002 | 06:32 PM
dkrzan's Avatar
me again
my dad said somethin about my problem. he said that if tthe wires and conections in the back get wet they will short or somethin and the car wont run. well i just found out that one of my quarter panels are leaking during rain, and the back padding is soaked. could this cause my problem?
thx dkrzan
Old Nov 20, 2002 | 10:31 PM
Ghostz's Avatar
Well, maybe one more
From: Far away, locked up from anything interesting, almost in the dead center of the US
Re: me again
Those wires are the connections to the fuel pump. Yes, if they get shorted, the car won't run. If they do short, the fuse will blow, and your car would not run again until you fixed it. Also they are almost centered under the rear deck carpet, not so much to the side that you are experiencing a leak in. Get the leak fixed!!! Rust sucks!!!
Ghostz
Old Nov 21, 2002 | 12:21 AM
ZenArcher's Avatar
Re: me again
May be the taillight housing seal or 1/4 window seal that is leaking. Both are sealed with butyl tape, black gunky putty-like stuff. Easy to fix but a messy PITA.
ZenArcher
Old Nov 21, 2002 | 07:14 PM
dkrzan's Avatar
Re: me again
i was gunna change hoods. my hood flew up and is bent outta shape. i was gunna put a hood on from another z. same year but not turbo. do i need to get that scoop put in or is it just supposed to be a thing they put on turbos in 85 just for the look. thx
Old Nov 23, 2002 | 03:03 PM
ZenArcher's Avatar
Re: me again
It has some small effect but necessity no. When I bought my 85t it came with a damaged hood. The scoop was stolen soon after. I had plans to replace the hood so I experimented with louvers. I think they worked better at dissipating heat but when I replaced the hood I didn't use them. You can find scoops on ebay and in the classified ads here and at the other z31 sites. Or a junkyard. <a href=http://jboykin@users2.ev1.net/~jboykin/mycar.htm target="_blank">my car</a>
ZenArcher
