Low idle on startup when its cold.
Old Nov 24, 2002 | 11:06 AM
ZenArcher's Avatar
Re: Low idle on startup when its cold.
It does sound like the AR but could possibly be the CHTS ( cylinder head temp sender) needs to be replaced. There is a lot of good info on the 84-89 300zx at <a href=http://www.z31.com/ target="_blank">z31.com</a> but bring a thick skin and use the "search" feature when possible. Good luck.
ZenArcher
Old Aug 29, 2014 | 09:32 PM
Fairlady-Z31's Avatar
Originally Posted by ZRob
There is an easy AR check.
Take it off and put it in the refrigerator for 30 mins. then take it out and blow thru it. If you cant blow thru it, it's shot. Then, wait for it to warm up, there's a bimetal valve inside that should shut when it warms, if it doesn't close, it's shot.
Do yourself a favor, do a good tune up, change ALL the vacuum hoses,clean all the electrical connex you can see, and a new fuel filter. It'll save lots of headaches and give you much better performance.
I was wondering what is AR mean because I want to to check that when I know what is AR because im trying to get more and more things fix on my 84 300zx non-turbo
Old Aug 30, 2014 | 05:57 AM
Darcy Bekkema's Avatar
There is a screw on the idle up solenoid on drivers side of the plume that can be adjusted to turn up the idle. I purchased a block off kit from Intake Manifold Block-Off Plate Kit - 1984-89 Nissan 300ZX & Turbo | Acadiana Sports Car Orphanage - Official Store. And then used the small set screw on the throttle body, it's under the accelerator cable.
Old Aug 30, 2014 | 10:17 AM
zxguy1986's Avatar
Cold idle rpms are controlled by the idle-up solenoid on the air regulator. Check out diagram EF&EC-4 in your factory service manual (you got it at XenonZ31 Reference for free!) Easy enough to test it with a multimeter. Take the solenoid out, apply current to the feeds and listen for the click - if it's working. If it isn't, I'm surprised you can idle at all. Should stall out right away if that solenoid is dead
Old Nov 4, 2014 | 01:23 PM
sar82007's Avatar
Same question what is AR?
Does anyone know what AR means? I am having the same problem my Z will needs throttle to start and hold for a minute then idle evens out. If there is no throttle it might start then die. Things I've checked are the spark plugs, fuel filter, lines that go to the fuel filter, throttle body sensor was also changed. None of those were the problem.
Old Nov 4, 2014 | 02:39 PM
zxguy1986's Avatar
Talking
AR = Air Regulator. It has two solenoids and is a big deal in idle control. Your factory service manual ( available free at XenonZ31 Reference - if you have a Z31 ) shows it. The solenoids can be tested for operation with a multimeter. Check the one shown in your manual as Idle-Up Solenoid. They die eventually.
Meanwhile, do everyone a favor. Sign in, go to User CP menu (upper left), click Edit Signature and add your Z model, year, shifter, turbo or NA, etc. Saves you having to add it to every post. (Guys here go crazy if you don't lock your Q to your specific Z every time you post...They just ignore questions without enough info) Then click Edit Avatar and add a little Z pic under your nick. Cool. You are solid here
Old Nov 4, 2014 | 04:45 PM
sar82007's Avatar
Thanks
Thank you for the help. I'll add a picture eventually I just have to take one.
Old Nov 22, 2014 | 05:10 PM
sar82007's Avatar
For whatever reason the problem has subsided as if by magic. No problems starting up yet.
Old Nov 23, 2014 | 03:00 PM
zxguy1986's Avatar
See? All you need to do is own and drive a Z31. The magic is included at no extra cost.
Old Nov 26, 2014 | 05:22 PM
sar82007's Avatar
RE: Magic
As great as that is it would seem I traded one evil for another. My heater doesn't work properly. When the heat is turned on the defroster and driver foot well are the only getting heat. The passenger side blows cold air. In another instance I'll turn the heat on and there is no hot air at all. I've researched this that it may be the watercock. Some people have zip tied theirs shut.
Old Nov 26, 2014 | 10:05 PM
zxguy1986's Avatar
Yeah. Had the same prob for a couple of years with my '86na. I think it's a combo of the vacuum pump getting weaker and the damper doors slowing down/stopping. The zip tie thing works on the water ****. When you need AC, switch the zip tie in/out - I forget which. Did it every spring/fall for 5 years.
Best thing is to replace all your vacuum tubes for a start - before you replace pump(s) and take dash apart to clean dampers. If the tubes are leaking even a little, the system doesn't work right. Check out Thumper's analysis at Vacuum Lines Try to do it right if you can. (Tube diameters are a big deal in this) Take your time and do one tube at a time so you don;t screw up.
Old Nov 27, 2014 | 11:23 AM
cbernone's Avatar
Check water temp sensor by water pump convey message to ECU about temp.
Old Nov 27, 2014 | 11:24 AM
cbernone's Avatar
Check water temp sensor by water pump sends temp to ecu
Old Jan 31, 2015 | 10:15 PM
sar82007's Avatar
Thank you guys
Sorry I didn't get back sooner. Happy new year everyone. I will definitely have to check these things out.
zed head
Jul 10, 2010 01:42 AM
thetremendousti
Nov 6, 2007 06:44 AM
ZYALTR
May 21, 2003 07:27 PM
Wolfe
Dec 24, 2001 09:55 PM
rlh1
Apr 17, 2001 04:11 AM
