I don't know what tha hell is goin on..
Old Aug 5, 2010 | 12:54 PM
preludetwofast's Avatar
So My 84 turbo is acting really weird, If i hit tha gas at idle it bogs down, or barely revs, but if i sit there and pump the pedal, once it gets over 3k it runs fine, i just have to keep it above 3k. If it goes back down then I have to repeat the pumping process all over again.. Anyone have a clue about whats going on?
Old Aug 5, 2010 | 01:01 PM
Gixxer's Avatar
Is it possible the fuel filter is clogged a bit? I had a 240 when I was in HS and the FF ALWAYS clogged because we had REALLY crappy gas in KS
Old Aug 5, 2010 | 01:04 PM
Pull ecu codes........
Old Aug 5, 2010 | 01:07 PM
as soon as it quits raining thats what I'm gonna do, I just looked up how to pull my codes..
Old Aug 5, 2010 | 01:23 PM
duowing's Avatar
NisTuner
Probably a bad CHTS, MAF, or both. I think above 3K RPM the ECU kind of kicks into open loop and that's about when most of the sensors stop really mattering as it's just running off the pre-programmed fuel maps in the ECU. Don't hold me to that though. I just remember when my 280ZXT had a bad CHTS it would run awful until you hit a higher speed, for me 65mph on the freeway, it would be over 3K and ran beautifully. If only I'd have known that then, it would have saved me a lot of headache.
Old Aug 5, 2010 | 01:25 PM
thanx I'll look into that..
Old Aug 5, 2010 | 01:57 PM
what exactly is a chts?
Old Aug 5, 2010 | 02:12 PM
^Cylinder Head Temperature Sensor or Sender
Old Aug 5, 2010 | 02:15 PM
ok thanx
Old Aug 6, 2010 | 02:25 AM
^ No problem man, anytime.
Old Aug 13, 2010 | 10:43 AM
turbotim's Avatar
Dont forget to inspect your 02 sensor too!
Old Aug 22, 2010 | 06:30 PM
ok so i ran the codes, and the only one other than 14 and 31, which from what I gathered are supposed too show, the only other one was 23.. It said Idle switch, I called my local parts store, and they didn't even pull up an idle switch, so what now?
Old Aug 22, 2010 | 06:55 PM
Idle switch = TPS (throttle position sensor).
Old Aug 22, 2010 | 08:44 PM
thanx
rgus30
Oct 10, 2006 11:52 AM
snwbrderphat540
Feb 10, 2006 03:40 PM
NismoPick
Nov 13, 2005 07:00 PM
VenomousZX
Sep 1, 2005 04:54 PM
DarrellBuddy321
Jun 29, 2005 08:41 AM
