How Hard would it Be....
Old Sep 19, 2003 | 02:42 PM
Zcarninja's Avatar
burgerflippin' bastard
does the turbo motor run? if so, then its easier to swap the whole engine than it is to swap heads. if not, the heads and intake will fit just fine. if yoiure not very experienced with turbo engines, i wouldnt attempt putting the turbo charger on the n/a engine.
Old Sep 21, 2003 | 08:12 AM
johnZboy's Avatar
Distinquished Guest
Actually, the higher compression of the N/A engine could be a plus. You would need less boost to achieve the same net results.
However, if the turbo engine is a good one, I'd be more inclined to just use it. It would make everything more simple and simple is a good concept.
Old Sep 22, 2003 | 06:23 PM
Zcarninja's Avatar
higher compression=less boost. you'd have more power potential just using the lower compression turbo engine. however, if youre not concerned with using higher boost, the n/a engine with a turbo will have better low-end torque...so ive heard.
315driver
Jul 10, 2012 08:25 PM
SinCity350Z
Aug 30, 2005 08:59 PM
unique280
Aug 13, 2005 09:18 PM
juggalo280ZX
May 9, 2005 05:43 PM
CHSTigersFan
Sep 28, 2004 09:48 PM
