How do I remove the camshaft?
Old Aug 27, 2010 | 02:48 PM
xxVERITASxx's Avatar
I have the Haynes manual and FSM for the Z31. Can't find a spot that tells how to remove the camshaft. Do I need to take off the cylinder head and rocker arms to get to it? or can i just get it from the front and rear? Please HELP!
Veritas
Old Aug 27, 2010 | 03:00 PM
Alright, this is really easy. Pull upper plenum to get the driverside valve cover off, pull off both valve covers, set #1 at TDC, pull the front covers and the timing belt, remove dizzy, pull valve covers, remove rockers, remove lifters and lifter guides, remove cover plate on the back of the head, remove the bolt in the back of the cams, and slide the cams out gently.
Old Aug 27, 2010 | 03:24 PM
will i have to replace gasket when i pull off valve cover? And I'm only trying to pull the driver (LH) side camshaft.
thanks for the quick response btw
Old Aug 27, 2010 | 03:29 PM
260zturbo's Avatar
Stupid Hurricanes...
if the gasket is in good shape no...if its rotted then go ahead and replace to save you some headaches.
Old Aug 27, 2010 | 03:30 PM
Here's a diagram...
Old Aug 27, 2010 | 04:15 PM
how do i remove the upper plenum? is that the intake control assembly?
Old Aug 27, 2010 | 04:37 PM
260zturbo's Avatar
allen head bolts.....
Old Aug 28, 2010 | 04:18 PM
So I got down to the camshaft after taking off the valve lifter guide. The retaining bolt at the rear of the camshaft won't come out. I think the head is getting stripped. How do I keep the camshaft from rotating while trying to unscrew the retaining bolt? Do i even have to remove the retaining bolt or should the camshaft just slide out?
Old Aug 28, 2010 | 06:22 PM
UPDATE! Just got the rear retaining bolt out. Now the camshaft slides about a centimeter but will not pull out of the front. It sounds like it is hitting something, like it is being blocked from the front. Any Ideas?
Old Aug 29, 2010 | 02:14 AM
My bad, I totally forgot about the cam seals. Remove the cam gear and you can use a pick to remove them.
Old Aug 29, 2010 | 12:34 PM
Thank you guys for all your help. I was able to (with extreme force) get the rear retaining bolt out. Then I used a hammer on the rear of the cam and knocked the oil seal out and the cam was free to move out. Now time to buy one and put it back in. I'd put up a pic of what my old cam looks like but I don't have a camera. Trust me though, the gear on the cam is FUBAR! Bad. But thanks again all.
campfirestring
Jul 12, 2012 08:04 AM
ekset22
May 21, 2012 10:45 AM
n00blar
Aug 1, 2006 09:17 AM
OlderThanMe
Oct 19, 2004 10:10 PM
jake
Nov 3, 2003 07:55 AM
