high idle, tried searching
Old Sep 23, 2013 | 11:49 PM
cords z31's Avatar
ok so I own a 1984 Datsun/Nissan 300zx turbo 50th AE
My issue is that the car when cold started will shoot up to 2000 rpms for about 1 minute, after that it goes down to 1200 rpms. if the car is still warm, it will fire up and idle at 1200 right away.
The car will run fine and I have power and everything else seems to be working, is this a big deal?
things I have tried:
-2 different MAFS (is it possible both are bad?)
-all new vacuum lines
-new cap and rotor, wires are good.
-tried timing the car, its at 20 degrees, where it should be, but that is with a 1200 idle. if I try to move the distributor, one way it will just sputter and stall, and the other way just races the engine???
-sprayed brake cleaner all over the intake and the vacuum lines and no change in rpms
-tried un plugging the O2 sensor and the car runs the same with it plugged in or unplugged (could this be the problem?)
-2 different ECU's
I guess I can try and buy a vacuum tester kit, and a compression tester, not sure what else to try, maybe someone has had the same issue and can lend me any knowledge please and thank you, much appreciated, I will try anything that you guys suggest.
Old Oct 2, 2013 | 07:44 PM
cords z31's Avatar
my TPS was hooked up wrong, what a fail haha! I never thought of it because that's how I bought the car, it wasn't running due to ecu being fried, right from first start up it had a high idle, but the TPS wires fixed that.
madkiwi
Jun 6, 2015 07:40 AM
v0va
Feb 23, 2005 12:27 AM
rookey1
26
Mar 5, 2004 09:24 AM
pretender84
Oct 8, 2002 07:02 AM
DANZAMAN
Sep 22, 2002 09:11 PM
