High Idle
Old Feb 16, 2005 | 07:20 PM
v0va's Avatar
Russian Pimp
High Idle
So my car started idling really weird above 1-2k, here is the video of that
http://www.photodump.org/stored/highidle.wmv
After that i took someones advice and playes with the idle screw and made it idle at around 800-900, but now like when i rev it, it goes down to 1k, then goes up to 1.5k and drops down to 800-900 heres a video, anyone have any idea wut i should do ?
http://www.photodump.org/stored/idle.avi
Old Feb 16, 2005 | 07:25 PM
91zxtt's Avatar
Put the idle screw back to where you had it. That wasn't your problem. By adjusting the idle screw you are merely masking another problem. You likely have a vacuum leak somewhere. Try cleaning your throttle bodies as well.
Old Feb 22, 2005 | 12:19 PM
reefatx's Avatar
check you tps; your tps should check out at about .45 volts
Old Feb 22, 2005 | 08:09 PM
91zxtt's Avatar
That's at WOT. It's lower at idle, but I can't recall exactly.
Might I suggest Rizz's link page.
If it just started doing it, then I'm guessing vacuum leak.
Old Feb 23, 2005 | 12:27 AM
Riz Z Speed's Avatar
Administrative Brown Guy
any of this sound familiar to you vlad?
madkiwi
Jun 6, 2015 07:40 AM
garretthes
Feb 4, 2012 09:17 PM
rookey1
26
Mar 5, 2004 09:24 AM
pretender84
Oct 8, 2002 07:02 AM
DANZAMAN
Sep 22, 2002 09:11 PM
