High Idle + Rev hang when shifting!..HELP!
High Idle + Rev hang when shifting!..HELP!..UPDATED
So I picked up a 87 Turbo yesterday and I freaking love it although it has these pesky issues. Ive searched and read about the Idle being too high and I am going to change all the vaccum lines and see what happens. BUT what really got me worried is when the car is moving and I depress the clutch to shift up or down the revs stay up there hanging until I let the clutch go!...what could be causing this??...I was thinking over boost??..but then again its bone stock with the exception of a K&N filter...any help would be appreciated, thanks in advance.
By dtmkarnage at 2011-07-01
check your air idle control its on the right side of the manifold if you're looking at the car from the front, it's a little thingy that has a screw to adjust the idle (excuse my use of the word thingy idk how to explain what it looks like) and it should be in the middle og the mani on the right side.
may be it is the air IDLE CONTROL valve so try with that and what does your car idle at my 88 turboidles at 700rpm all day every day! and when i got it it idles at 12000 rpm all it needed was the adjustment but be careful not to strip or over tighten the set screw.
I order for any engine to run at all it needs air. If your RPM's are high or not returning to idle air has to be getting into the take some how. Track down every source of air. You can temporarily remove and plug lines from things like the FICD etc until you effect a change.
Keep in mind that because you are not saying it runs like **** chances are the air that is getting in must be going through the AFM otherwise it would just run bad like if you took a vacuum line off. I'd start with the hose going to the AAC/FICD. Pull it and plug both ends and drive it.
Even if the ECU was dumping to much gas into the cylinders the engine would not race, it would just flood and die. It needs air.
One of those connectors looks like a O2 sensor and the other might be a throttle position . I'd have to go look at our car to be sure.
madkiwi
Jun 6, 2015 07:40 AM
zawahra
Jul 5, 2014 10:14 AM
