Help! Failed emissions
Old Aug 6, 2002 | 10:19 PM
ZenArcher's Avatar
Re: Help! Failed emissions
After a basic tuneup and oil change the CHTS, o2 sensor, and cat are the best suspects.
ZenArcher
Old Aug 7, 2002 | 06:22 AM
Spot's Avatar
make sure you check the vac hoses, and set the timing properly.
try using ngk plugs, not bosch. bosch ones run hotter, and higer heat in the combustion process will drive nox emiisions up.
one way to test the cat, is to take temp readings just before and just after it. coming out of the cat should be about 150 degrees hotter than going in.
007max
Feb 6, 2008 11:16 AM
lrms515
Sep 1, 2007 04:24 PM
JohannB
20
Jul 17, 2005 03:39 PM
Red-Eye
Apr 25, 2005 03:28 PM
yomammaZ
Nov 29, 2003 04:22 AM
