Failed Emissions - Not even close
Old Feb 22, 2005 | 10:01 AM
Red-Eye's Avatar
Hello, this is my first post to this forum, as my '83 280ZX NA has never given me any grief, til now. Here's the numbers at 2529 RPMs:
HC Reading = 2357, Limit = 220
CO Reading = 9.57, Limit = 1.20
Background of my car:
I'm the 2nd owner, and it has 123,000 miles, about 6000 miles per year. I just did the following about a week ago - Mobil 1 oil, Oil Filter, NGK Plugs, Fuel Filter, EGR Valve, Cleaned the K&N Air Filter, new Turbo Muffler. About 4 months ago, I had the dizzy rebuilt by Kim at Idaho Z. And over the last couple of years, I've replaced the Plug Wires, Dizzy Cap & Rotor.
My mileage has definitly dropped, now at about 16.5 MPG, seems like it was around 20 MPG when I bought the car about 5 years ago. The car's running pretty good.
TIA...Robert
Old Feb 22, 2005 | 10:34 AM
Replace the fuel pressure regulator! Your fuel pressure is probably sky high.
That's what mine was like. If you idle your car for a while (30 secs) and then give it a quick rev, do you see black smoke shoot out?
My stupid car failed emissions for the second time now... it got worse barely. I'm going for a new oxygen sensor next. Oh, replace your oxygen sensor too along with the pressure regulator.
Old Feb 22, 2005 | 12:18 PM
Red-Eye's Avatar
Thanks BleachZee. Can I get the Fuel Regulator & Oxygen Sensor at NAPA, or are these Stealer items?
Where can I see a pic of your '70 Fairlady Z?
Old Feb 22, 2005 | 12:36 PM
Yes, Napa should have both. Or, if they don't you can order them online from Importedcarparts.com
Page 2 and 3 of my Zdriver gallery has some Fairlady Z pictures.
https://www.zdriver.com/gallery/show...500&ppuser=464
Old Feb 22, 2005 | 02:29 PM
Red-Eye's Avatar
I'm looking at my FSM. When you say Oxygen Sensor, is that the same as the Air Regulator?
Where did you get that '70 Fairlady Z? I've seen a Fairlady ZX here in ABQ, but the guy had swapped drive trains.
Old Feb 22, 2005 | 02:55 PM
The oxygen sensor is on the exhaust manifold. The air regulator is the Air Flow Meter on the intake pipe.
I got the Fairlady Z in Washington. Its one in a million chance to find one. Especially the early ones with original drivetrain.
Old Apr 25, 2005 | 08:07 AM
Red-Eye's Avatar
Passed Emissions
In case anyone cares, here's what I did to get thru emissions
1) Replaced the fuel pressure regulator
2) Replaced the O2 sensor
3) Replaced all vacuum lines
4) Fixed a leaking injector
Thanks for your suggestions BleachZee...Robert
Old Apr 25, 2005 | 02:28 PM
DoTheDrew888's Avatar
Did you notice any difference in performance after all that?
Old Apr 25, 2005 | 03:01 PM
Red-Eye's Avatar
No, not really, just better gas mileage
Old Apr 25, 2005 | 03:28 PM
Oh, BTW I see that in the posts above I too was failing emissions. A new oxygen sensor did the trick.
007max
Feb 6, 2008 11:16 AM
lrms515
Sep 1, 2007 04:24 PM
JohannB
20
Jul 17, 2005 03:39 PM
yomammaZ
Nov 29, 2003 04:22 AM
rngrck
Aug 7, 2002 06:22 AM
