Engine Swap
Old Feb 6, 2002 | 10:18 AM
Spot's Avatar
Re: Engine Swap
There is no such thing as an 86 limited edition anything. the turbo engine has about 40 more stock horses, Why not use the clutch from the 86T?
i would guess a competant shop would charge about 700-1500 for an engine/tranny swap if you supply all the parts. (this is a wide range, but you will find places that will charge you alot especially if they really don't care to do that type of work.) you will need the front crossmember and intake piping and driveshaft at the very least, along with the ecu and efi harness, but if you have the entire car then you should have all that you need. (there are other sensors and gizmo's you will also need).
Deafwolfy
Apr 30, 2015 05:19 PM
blacksheep
20
Mar 27, 2007 01:18 AM
uk175
Feb 5, 2004 05:42 PM
smokingzcar
Dec 5, 2002 07:57 AM
dstyle
May 13, 2002 06:14 PM
