Dirty Engine
Old Jan 26, 2006 | 04:05 PM
91Zman's Avatar
Opinionated
Dirty Engine
My engine is pretty gross looking. Covered in dust and all sorts of crap. What should i do to clean it up and make everything look all nice and sparkly
Old Jan 26, 2006 | 04:35 PM
I think washing it would be a good start... use some degreaser & mid-pressure washing nossle. cover the distrib w/ a plastic bag, so you don't have a hard time starting it afterwards.
Old Jan 26, 2006 | 05:30 PM
91Zman's Avatar
Opinionated
as for the degreeser get that at like the autoshop correct?
Old Jan 26, 2006 | 08:37 PM
84zman's Avatar
yeah...im interested too....just spray the engine down with water and all the electrical stuff will be fine gettin wet???
Old Jan 27, 2006 | 01:04 AM
entropy31's Avatar
The Cake Is A Lie!
pressure washed the motor in my '87 and never had a problem. and yes, an auto parts store is the place to get de-greaser. i've had good luck with the "gunk" brand products.
Old Jan 27, 2006 | 02:07 PM
AZ-ZBum's Avatar
I can't believe I just read a question asking how to clean something.
HOLY CRAP!
Goto cleaning aisle.
Grab "ENGINE CLEANER".
Read instructions on label.
Do you need instructions included with a bar of soap also?
Old Jan 28, 2006 | 07:59 AM
WolfMan's Avatar
No worries all, az-zbum forgot one of the notes in this forum, the one that states be nice, everyone is learning. But yes go to any autostore and purchase a degresser. Make sure your wires are not bare, cover your distributor and all should be good from there..
late
Old Jan 28, 2006 | 09:11 AM
91Zman's Avatar
Opinionated
late
Thank you
Old Jan 28, 2006 | 10:21 AM
WolfMan's Avatar
No problem, I really like az zbum, he is very smart when it comes to the z31 frame. So dont get me wrong az, your info has helped everyone in this forum at least once!!!!
Old Jan 28, 2006 | 07:39 PM
Oxide's Avatar
You could always take the hood off and run it through a car wash. Just don't use the wax cycle.
Old Jan 28, 2006 | 07:43 PM
japanz's Avatar
If you are worried about the electrical connections getting dirty use Simple Green, old toothbrushes and rags. That and good ol elbow grease will make it look pretty darn good when you are done.
Old Jan 28, 2006 | 08:22 PM
91Zman's Avatar
Opinionated
I just may be doing that
Old Jan 28, 2006 | 09:31 PM
What's the size ratio between an engine & toothbrush? I'm sure in time, it would equal several hundred hours of brushing? hum... pretty effective work there...
BTW... how ya gunna get down to the intake plentum, and lower parts of the engine bay w/ a toothbrush? Unless your arm has 3 to 4 elbows... it's not gunna happen.
Old Jan 30, 2006 | 08:39 AM
japanz's Avatar
lol several hundred hours is a bit of a lost thought there. Try it and put some effort in and you get results like this.
Ratio is
effort:result
Old Jan 30, 2006 | 08:42 AM
Ratio is
effort:result
So it only took 15 minutes to go from "pretty gross looking" to that, using a toothbrush? You're indeed very talented!
Old Jan 30, 2006 | 08:52 AM
WolfMan's Avatar
I want that engine!!!!
Old Jan 30, 2006 | 08:53 AM
japanz's Avatar
Well I will tell ya what then so we don't have to compare too much abut what not to do or should do.
You can go ahead with your "some degreaser & mid-pressure washing nossle" and take your chances of doing something potentially damaging. And I on the other hand will take my slightly longer than 15minutes and get a far greater detailed result and still be able to drive my car. Ok, that is all.
Thanks and you know what they say...
Old Jan 30, 2006 | 08:56 AM
LoL... explain to me what is potentially damaging (besides spraying it off when hot).
BTW... I used to detail cars as a job... I've washed thousands of engine bays & never had any problems.
Old Jan 30, 2006 | 08:59 AM
WolfMan's Avatar
I guess if you dont pay atteention whith what you are doing. I understand both sides, with my camaro, its all about detailin. I use both methods however, you use the degresser with a STEAM cleaner, and use the brush for the special peices.
thats the info I would stand by.
Old Jan 30, 2006 | 09:05 AM
japanz's Avatar
pissing match, great, here we go.
I will be simple.
Water + electrical = bad
I know you may think otherwise but maybe you have been very lucky and fortunate in your experiences. But hey, you seem to have the angle here. No waves needed, just an opinion and I say Simple Green will give you better results than the water method you mention. Fly at it NismoPick. I will correct myself though, I said "if you are worried about the connections getting dirty when I should have said getting wet ".
Thanks again but are we going to entertain the last word about what you think is best, maybe you missed my thank you.
Old Jan 30, 2006 | 09:11 AM
WolfMan's Avatar
lol, to each man his own!!!! Its inhuman to **** on each other, besides, I drank 4 mountain dews, I got you both beat. This is a place for suggestions. besides, I even said to look for bare wires and such, and that I use both methods. but if you use water, steam is the way to go, it will lessen the risk of cracking a hot block.
Old Jan 30, 2006 | 09:14 AM
AZ-ZBum's Avatar
These are the two cleanest engine bays I've ever seen. Neither were done with engine degreaser.
Old Jan 30, 2006 | 09:16 AM
WolfMan's Avatar
he is just showing off his car.
Old Jan 30, 2006 | 11:06 AM
entropy31's Avatar
The Cake Is A Lie!
last i checked, zbum doesnt have a white one.
Old Jan 30, 2006 | 11:22 AM
AZ-ZBum's Avatar
Neither car is mine. Mine are pretty dirty. But I'm not looking to eat off them either. Or enter any serious car shows with them.
edit: oh yeah. They were cleaned with toothbrushes and q-tips.
