Digital Dash
Old Sep 17, 2001 | 07:04 PM
silvrhand's Avatar
Snazzy Title
Re: Digital Dash
Another problem that seems to happen also is the connectors on the box start to rust or need some contact cleaning.
Clean both the cable and the box and use some eletrical contact gue (can't remember the name) on the leads.
Should work unless your need soldering as mentioned above..
- john
Old Dec 1, 2001 | 05:34 AM
Spot's Avatar
Re: Digital Dash
sure you can. you would need the correct sensors and wiring harness to make it work. It's a royal pain to do from what I've heard. You need the dash display, power supply, boost sensor, speedo controller, and various other sensors too. If you swap the dash, it won't match your pod gauges unless you swap those too. You will also need the wiring diagrams so you know how/where to connect which wires.
tdbaker156
Feb 1, 2012 06:06 AM
MikeyMojo
Dec 26, 2011 04:41 AM
marcello129
May 12, 2005 04:17 AM
chacharis
Sep 10, 2002 10:24 PM
barkly
May 30, 2001 11:43 PM
