Crazy highbeam problem!!!!
Old Aug 10, 2013 | 09:35 PM
CVTURBO's Avatar
Exclamation Crazy highbeam problem!!!!
I recently bought a 1985 2 seater manual non turbo z31. The highbeams do not work at all. when the headlights are on, and the highbeam switch is pushed or pulled, it just turns off the headlights and the lights continuously flip up and down. Other then that all else seems to work. Iv done my research and could this be the switch? Iv looked at all the fuses by the driver foot panel and non are blown. Do the highbeams have their own fuse seperate from the headlights? if so where is it located? Thanks in advance any help is appreciated
Old Aug 13, 2013 | 10:13 AM
reddzx's Avatar
classic symptoms of a bad headlight switch.
Old Aug 13, 2013 | 03:24 PM
aujbman's Avatar
Could be switch or could be something else. I had/have a similar problem. From the beginning when I pulled the switch to put the headlights on bright it would cause one to go out and the other to stay on. Every time I pulled the switch the headlights would switch between which one stayed on and which one went off. Replaced the switch recently and that problem is still there.
Old Oct 21, 2013 | 10:27 AM
CVTURBO's Avatar
Hey guys I fixed the problem, it was the switch. Here the video I made so it can help other people fix the problem
Link:
Old Jun 30, 2022 | 11:12 AM
jfavero's Avatar
Where is the video?
BlueKitsune
Apr 4, 2009 09:23 AM
Oxide
Mar 8, 2006 06:13 PM
bardabe
May 16, 2005 05:46 PM
NISMO LMR
Aug 27, 2004 06:33 AM
NISMO LMR
Jul 26, 2004 09:47 AM
