climate control
Old Dec 13, 2011 | 10:43 AM
mossyoak.1988's Avatar
Exclamation climate control
i dont have the digital climate control its the one with the buttons but no matter what i put it on foot face it wont blow out of any but the defrost and it always blows hot. i herd on some other site that there is a relay on the back side of the fuse pannel on the driver side but not sure. just wanting to get some other opinions. thanks
Old Dec 13, 2011 | 10:54 AM
Have you tried this? www.xenonz31.com/reference
Old Dec 13, 2011 | 03:50 PM
i have that on my comp i looked at it but it got me really confused im not the greatest with wiring
Old Dec 14, 2011 | 08:41 AM
Wiring? You should be checking the vacuum lines...
And the first google-machine result:
http://z31.com/phpBB3/viewtopic.php?f=5&t=13408
Originally Posted by AZ-ZBum
What they fail to remember is that the default setting for the climate control is full heat from the windshield vents. If you have zero heat period, chances are you heater core is blocked or bypassed. If you can control where the air is coming from, then you have vacuum.
Old Dec 14, 2011 | 08:48 AM
donr1494's Avatar
I've gone thru this a couple times with 84 & 85 with auto temp control. It was leaks in the vacuum system, either at the incoming line or, more common, a bad vacuum bellows on one or more of the control actuators. Unfortunately, the heater must be removed, a nasty job.
Mikey8907
Aug 13, 2014 06:49 PM
binZer
Sep 9, 2008 09:53 AM
linkarroway
Oct 5, 2004 06:10 PM
Airpilot16
Aug 30, 2003 11:59 AM
sheaznit300z
Apr 3, 2002 08:30 PM
