Clicking sound above Glovebox / behind Dash
Old Apr 8, 2018 | 12:38 PM
Daniel George's Avatar
Hey everyone,
my 1985 Z31 Turbo has an annoying clicking sound coming from behind the Dashboard, approximately above glovebox. The clicking is only there when the car is in complete stand with engine runnning. As soon as the car starts rolling (even without throttle) it will fade out. It also stops when I put the turn-signal. Did someone ever had this before? I understand it is most likely some broken relay, but which? Turn-Signal? I would be thankful if anyone has a hint or knows what it is and how to get there without taking the whole dash apart.
Thanks and kind regards,
DG
Old Apr 10, 2018 | 06:13 AM
86tcoupe's Avatar
The asperator fan , is known for strange noises
​​​​​​​or a blend door servo stripped
Old May 24, 2018 | 09:50 AM
Donn144's Avatar
I took mine out!
Not very difficult..it took a while to localize it..It was a few years ago..I do not recall if I had to remove the glove box or not...but either way,
I recall it was easier than I thought. Probably one screw holding it in place and one plug to unhook.
Old May 24, 2018 | 03:46 PM
86tcoupe's Avatar
You need it for the auto air to cycle right , but yea the noise if you clean the blades and oil the bearings it can get much better
imaad22
Jun 3, 2013 10:08 PM
LemonHead
Sep 26, 2012 08:56 AM
Jjona5
Jul 22, 2012 08:39 PM
305zx
FS: 300ZX (90-96)
Aug 14, 2011 10:19 AM
bataradena
Jul 25, 2010 07:35 AM
