Car Won't Stay On
Old Sep 21, 2009 | 10:09 PM
86300zx's Avatar
Car Won't Stay On
ok my car has been sitting in the garage for some time now, because i don't really know how to fix the problem. when i start the car it stays on for about a second or two then the rpm starts slowly going down to 0. also while the car car is on for the few seconds i step on the gas pedal just to see if it will help stay on a bit longer, it actually helps the car turn off and feels like there is a delay when i do press down on it. another thing is i've used some starter fluid while the car is on and this helps the car stay on longer but when i stop feeding it the fluid, it slowly dies on me. i have check the lines and fuel is coming to the motor, so if anyone could help i would highly appreciate it. THanks.
Old Sep 21, 2009 | 10:15 PM
how much gas do you have?
Old Sep 26, 2009 | 10:52 AM
jrealmuto1's Avatar
sounds like something i had , i just adjust my air to fuel and throttle adjustment screw, in the mornings i have to give it a little gas and cut my headlights on and it stays crank, after warmed up, it runs perfect. lol
Old Oct 31, 2009 | 01:59 PM
Z Car Barbie's Avatar
User Friendly
It sounds like your problem might be a sensor, such as the CHTS or O2. Try running the codes and see if it picks up anything.
Old Nov 11, 2012 | 12:13 PM
sluggo1246's Avatar
Old Thread...but I have the same problem...
What was the problem? Did you ever solve it?
Old Nov 14, 2012 | 08:08 AM
AZ-ZBum's Avatar
86300zx
Last Activity: 12-17-2010 12:15 PM
Somehow, I doubt you're going to hear from him.
KO1290
Oct 29, 2009 10:39 AM
Tak_Z32TT
Apr 24, 2006 10:35 AM
hyrumbradshaw
Dec 25, 2005 10:26 PM
duowing
Sep 25, 2005 09:55 PM
Mooney
Jun 18, 2005 08:22 PM
