car antenna won’t go up
Old Dec 20, 2023 | 04:29 PM
morgananfay's Avatar
Question car antenna won’t go up
Hi,
I apologise for bugging everyone but I am currently trying to fix my 86 NA’s antenna. I took the exterior pieces apart today and the antenna slipped right out (disconnected?), but the motor appears to be working. When I press the antenna button the interior, it responds with a click but the antenna does not go up but it did retract when pulled out manually.
Is the motor broken? Or is it something else? I do not have much car repair experience so I apologise if this is a dumb question. I also only have the chilton manual so I know I should probably pick up something else to help. Thank you for reading!
Old Dec 21, 2023 | 09:43 AM
Great White Zed's Avatar
Originally Posted by morgananfay
I apologise if this is a dumb question. I also only have the Chilton manual so I know I should probably pick up something else to help. Thank you for reading!
How far is up? How long is a piece of string? Now those are dumb quesions. Anyways...
1. Never underestimate the power of a Chilton or a Haynes manual.
2. In my case, the cable had broken. Once apart, you can get a new one should this be the case.
The replacement is usually comprised of a mast and cable. Available at the usual suspects. Repair instructions available here.
Old Dec 21, 2023 | 06:22 PM
Thank you! I appreciate it. I’m still new to car things and trying to figure out a z31 as a first project is proving a bit tough haha! Thank you again!
Twitch
Apr 14, 2009 02:10 PM
Comorat2x2
Dec 15, 2005 11:09 PM
pearly whites
Aug 26, 2004 11:51 AM
phrozen209
Aug 19, 2004 11:41 PM
tsefreeflow
Nov 11, 2002 05:18 PM
