86 Turbo project
Old Feb 28, 2014 | 07:40 PM
reddzx's Avatar
86 Turbo project
I can't wait to get started on my new Black 86 Turbo project. I have been building a parts stash for awhile now. I'll be starting on it this spring.
Fresh 87 T3 with clean manifold soon to be sent to Joel at AZ turbo for upgrade
86 Turbo motor with 95K, with fresh oil seals, valve cover and pan gaskets, timing belt, water pump and T-stat
88T 30A trans and drive shaft with 95K
88T CLSD w 135K
88 turbo front hubs
88 turbo front rotors
CM 3" turbo back exhaust with test pipe and 4" slashed tip
Z32 NA aluminum 26mm calipers with stainless brake lines
Powertrix 8k/6k coilovers
G-E bump steer spacers
Stance adjustable tension rods
Kouki front LCA's
Kouki RLCA's
New vented Kouki rear rotors, rebuilt rear calipers
MSA 1" solid sway bars
Full Prothene Poly kit with cross-member bushings
Rear cross-member with camber mod
Aftermarket Boost and oil pressure gauges
Cusco front Strut Bar
Complete 88 GL mint black interior
Analog guage swap
New custom black turbo floor mats
Corbeau GTS seats with Z31 adjustable tracks
Old Mar 1, 2014 | 10:32 AM
zxguy1986's Avatar
Sold! Msg me as soon as you're finished.
Old Mar 1, 2014 | 04:08 PM
reddzx's Avatar
I'll have at least $7000 in it by then
abosoxfan4life
Mar 21, 2014 08:28 PM
crazydude75927
28
Jan 14, 2008 07:36 PM
BoostL28
Mar 4, 2007 02:37 PM
Steven280ZX
Nov 25, 2006 04:21 PM
Neochron
Jan 14, 2002 10:07 PM
