Update on my project '83 turbo
Old Mar 3, 2007 | 07:55 PM
BoostL28's Avatar
Heres an update on my project 83' 280zxturbo: I've worked on it for the past 2 days straight have tried all the suggestions and checks you guys have given me unfortunately I still haven't found the problem. I did a complete tune up,timing..is ok, cleaned the throttle body, AMS, And Electrical Connections Clean Them Up And Used Dielectric Greese replaced vaccums and FPR,pcv,AR, I also added ISo-HEET and STABILL to the fuel system
After I did all of that I started her up she iddled perfect sounded great no vibration smooth purred but after she warmed up 15 min I hit the throttle she hesitated and died . I took the brand new spark plugs out again and they where floded with gas. As soon as I punch the throttle it floods the spark plugs and dies. The only thing that I haven't replaced are the injectors and the fuel pump. So what I'm saying is . Let me know what you think.
Old Mar 3, 2007 | 08:01 PM
RodMoyes's Avatar
Doesn't post much...
There are still a bunch of possibilities, but the most likely is that your AFM is toast... Have you tried re-adjusting it and cleaning it up like the "How to rebuild your AFM" thread suggests? Even if your AFM is toast, doing that should help a lot.
Rod.
Old Mar 3, 2007 | 08:10 PM
BoostL28's Avatar
Yes I cleaned it up llike the " How to rebuild your AFM" thread suggests but I dont know how to re-adjust it. I couldn't find no regulator or nothing to adjust, so if you know how to let me now, Thanks.
Old Mar 3, 2007 | 08:15 PM
RodMoyes's Avatar
Go back and read that thread again. It spells out in great detail how to adjust the spring in order to lean or enrich the final mixture. The spring tension determines the overall mixture to a large degree. Adjusting it per that threads instructions should get you some decent results if not solve your problem all together.
Rod.
Old Mar 3, 2007 | 09:29 PM
Could be AFM, CHTS, TPS, Timing....
Old Mar 3, 2007 | 09:49 PM
BoostL28's Avatar
hey wats the CHTS? timing is ok, TPS is new
Old Mar 3, 2007 | 09:57 PM
RodMoyes's Avatar
Cylinder
Head
Temperature
Sensor
On the top of the block near the head between spark plugs for 5 and 6 (roughly).
It's the only sensor in that area so it shouldn't be hard to find. If I had a pic handy, I would post it...
Rod.
Old Mar 3, 2007 | 10:05 PM
the afm adjust is pretty easy. ill walk you thru quick like, so ya dont have to read and interpret. first remove black side cover off unit. look at it. it has a large circular gear (made of plastic, usually black) at the top left, there is a little tab with a phillips/ hex head. while holding the gear, loosen the tab a little (just enough to move the gear) then tighten it a few teeth. in your case try 10 teeth. tighten the little tab. IF you let go of the gear. try placing it back where you started, and adjust it carefully. i usually adjust this while the car is running, so i can hear the change, and can up the idle as i go. try this and report back, it takes a few tries, but it will get you rolling till you can get it thru emmisions for testing, or if ya got cash, dyno tuned. dont make it too lean, youll be sorry. in daylight, there should be a little black haze behind the car, not much.
Old Mar 4, 2007 | 02:37 PM
FubarI33t's Avatar
shady. Does this work for N/A AFM as well?
BoostL28
Feb 26, 2008 12:58 PM
BoostL28
Mar 17, 2007 11:42 AM
Steven280ZX
Nov 25, 2006 04:21 PM
DiceSetter
Jul 27, 2006 11:46 AM
NISMO LMR
Oct 30, 2003 04:51 PM
