86 turbo power loss
Old Nov 28, 2010 | 05:17 PM
86_VG30ET_Z31's Avatar
Unhappy 86 turbo power loss
I been having this problems for about two weeks. When i shift to first gear an i rev it up it would hessitate an when i hit about 2700rpm it kicks in an gains all the power back but when hitting 4700-4750 its start to miss an back firing am it would have trouble gaining speed at this rpm range. When shift to another gear a cloud of black smoke comes out the exhaust an it does it every gear an fuel comsumption is really bad. I have replace a lot of things an still have the same problems things i have replace Timing Belt, water pump, dist. rotor, dist. cap, spark plug wires an spark plugs, fuel filter, air filter. I have check the cylinder compresion on the engine an it all came out around 149 to 152psi all of the injectors are working an i tried pulling the ecu code an only the a/c code comes out, tested the ignition coil an ignition control module an they came out good, also tested the maf sensor an came out good too i have replace all the vaccum hoses an the pcv valve i just ran out of ideas fuel pressure is good an fuel pressure is working good. Some one suggested me dat it might be the cat-converter clogged up but i havent checked dat yet any help would be appriciated.
Old Nov 28, 2010 | 09:25 PM
AZ-ZBum's Avatar
timing sounds off or fuel pressure could be wrong.
Old Nov 28, 2010 | 11:19 PM
the ignition timing is set to 20 degress BTDC ill double check everything an the fuel pressure again. thanks ill keep u posted about it
Old Nov 28, 2010 | 11:33 PM
What heat range plug are you using?
Old Nov 28, 2010 | 11:37 PM
I have NGK Iridium spark plugs its says heat range 6
vg30de
Jun 11, 2013 10:53 PM
Fozy
Mar 28, 2011 07:42 PM
mikesz
May 29, 2008 11:06 AM
Cw2435
350Z Performance / Technical
14
Feb 22, 2004 10:33 PM
Cw2435
Jan 18, 2004 05:29 AM
