84 z31 clutch problem
Old Apr 2, 2003 | 07:39 AM
Spot's Avatar
check and see if the clutch master is leaking inside the car - look up by the pedal where it goes through the firewall. If it's leaking then there's your problem. You have 2 choices then - new clutch master or rebuild kit for the one you've got (it's easy to rebuild).
when you're done make sure to adjust the pedal. You should have a slight bit of play before the clutch begins to disengage.
Yardjass
Apr 8, 2012 07:58 AM
snwbrderphat540
28
Apr 29, 2008 11:43 AM
anyrug
Mar 11, 2007 08:05 PM
Fourtunata
Jul 30, 2006 04:31 PM
MarkieMark
Sep 13, 2005 05:25 PM
