'84 slicktop update and a question
It's been slower than I would like, but progress is being made on the little white car. Changed the interior color from tan/ beige to mostly parchment (SEM vinyl stuff) and rebuilt the seats with a z32 pattern cloth. So far, she runs good, but will not run out. Max speed on the highway is around 70 mph. Seems to rev smoothly but slowly. So far, I have replaced plugs dist. cap and wires, changed to PRW module, replaced timing belt and associated hardware, changed fuel filter and checked pressure, cleaned MAF sensor, new clutch master and slave (bypassed damper) fresh panel air filter. Tried a tank full of some expensive injector cleaner and checked brake calipers for binding (one seemed a little tight from the parking brake spring bracket not moving, but some oil and movement fixed that). Timing is set at 20 degrees.
The question is for anyone who can think of something I have overlooked. Any ideas?
Thanks. doclee462@yahoo.com
Follow up
Excellent. Check advance on distr, both mechanical and vacuum, Good bet more power will be found in either not functioning proper. Need the advance when we push the happy pedal, Then a set of new injectors and connectors. Badda bam
Okay, all the mechanical and almost all the interior stuff has been taken care of. Still need to swap out the faded odometer barrels, or possible the entire instrument panel with a spare, find out why the HVAC system isn't working (I got nothin' so plan is to pull the dash apart and look for some bad vacuum hoses).
Next is paint and body along with a new windshield. Then, of course, all will be well and i should never have to fix anything again...right?
