1988 300zx not starting
Old Mar 14, 2013 | 12:17 PM
Micah.Crews's Avatar
hello, i own a n/a 1988 nissan 300zx 2+2. one day after driving i turned the car off and then i turned it back on 5 minutes later and the starter wouldnt even turn but the battery worked and was charged fine. i replaced the starter and the new starter slowly turned. the car would only start half of the time so i would have to jump it off. then i went and bought a new battery, i installed the new battery and its still the same problem. i have narrowed it down to a couple possibilities
1.starter is not correctly installed therefore not getting enough current
2.negative cable that is connected to starter could be faulty
3. there is a vacuum line that is cut and i do not know where it goes. it is on the far right next to the MAF sensor. i know that in my 86 there is a pipe to connect it but in the 88 that small pipe is not there and there is no sign of a broken piece there.
if anyone can send me a picture of a 1988 non turbo maf sensor with the solenoids by it then that would be great. the vacuum line is connected to a soleniod but i dont know where that leads to. i would like quicker responses so if you can respond to be by text that would be good. 478-952-0357
Old Mar 14, 2013 | 10:30 PM
Start with this. Check / remove / inspect / replace both + and - battery cables. With a fresh battery and starter, you should be able to crank it full speed.
MyDreamZ
FS: 300ZX (84-89)
Mar 11, 2009 10:50 PM
jonschaefer
Mar 1, 2006 01:50 PM
nismo619
Jan 22, 2006 02:13 PM
88_ON_17s
Dec 28, 2005 12:22 AM
00Evan
May 1, 2003 01:17 PM
