1987 300zx automatic transmission shift linkage
Old Dec 21, 2017 | 09:22 PM
felixthatcat's Avatar
My shifter is not alligned properly and I'm having to shift between park and reverse to reverse, slam it into park to not roll, in between neutral and drive to get into drive. It's a real pain and sometimes the car won't start until I slam it into park 3 times and I never not use the E-brake because it will roll if it's not completely in park. I don't know how to fix this issue and can't find any parts online.
Old Dec 22, 2017 | 11:26 AM
86tcoupe's Avatar
There is a adjustment undernieth, are you saying the parking pawl does not work? if The shift interlock is miss aligned,inop ,etc. It can bind too
​​​​​​​are you depressing the brake pedal ,as required,there is some adjustment in the cable
Old Dec 22, 2017 | 03:10 PM
I'm saying the indicator is completely off and also that park doesn't lock in place either.
Old Dec 23, 2017 | 02:18 PM
86tcoupe's Avatar
[QUOTE=felixthatcat;346846]I'm saying the indicator is completely off and also that park doesn't lock in place either.[/QUOTE
almost sure the indicator moves with the cover slide mechanism
the locking gear selector may be cause it is not going full forward
​​​​​​​try removing the cover slide to test IMO
Old Dec 23, 2017 | 02:39 PM
[QUOTE=86tcoupe;346849]
Thank you for the help so far. As far as your advice in this post, how would I test this without the indicator? Am I just changing gears and seeing if park will engage naturally when shifted all the way if the gear indicator slide was defective and blocking it from going all the way forward?
Old Dec 24, 2017 | 09:20 PM
86tcoupe's Avatar
You need to pull the indicator bezel off , maybe you just have debrei in the mechanism
but also the shift interlock comes into play( you have to depress the bake pedal to disengage a lock ,kids were shifting the lever ,engine running )
look for extreme play or wear inthe linkage
The_Ikon
Jul 7, 2016 08:39 PM
tyler2800
Feb 26, 2013 02:54 PM
Dspuds
Mar 5, 2011 02:40 PM
jhussey
Feb 9, 2010 10:53 AM
RichardZ32
Aug 2, 2007 09:33 AM
