1985 Nissan 300ZX Base Relay
Old Oct 1, 2017 | 05:02 PM
Drewcole5150's Avatar
Could this be why my Z31 wont engage when the key is turned over? If so where could I purchase missing relay?
Old Oct 1, 2017 | 06:34 PM
86tcoupe's Avatar
yes you need the theft and inhibit relays
they are a standard relay ,I am almost certain parts stores should have one
you can swap the ascd & light relay
Old Oct 1, 2017 | 07:53 PM
The Inhibit isn't wired but the theft relay (starter) is not the same as any other relays in the car. i will try my local parts store in the AM. Thank you!
Old Oct 2, 2017 | 07:21 PM
86tcoupe's Avatar
manual trans huh
yes check the wiring diag.
​​​​​​​you can jump the contacts to try it
Old Oct 3, 2017 | 09:12 AM
Originally Posted by 86tcoupe
manual trans huh
Yes it is a Manual Trans. How would I go about jumping the contacts? Thanks
Old Oct 4, 2017 | 07:47 AM
86tcoupe's Avatar
look in the wiring diagrams
also see if you have the power to trigger the relay
inhibit relay is you have to have the brake pedal firmly depressed before it will shift out of P
man trans had a clutch swt. the same way
checked mine ,yes 5 wire ,
mine has # 25230 C9961 part #
Desert Rat
FS: 300ZX (84-89)
May 2, 2016 12:30 PM
wrenchwench
Apr 6, 2015 03:27 PM
wrccruz
14
Oct 30, 2014 05:47 PM
awarzec1
FS: 300ZX (84-89)
Sep 11, 2014 08:16 AM
Creator
May 31, 2004 12:59 PM
