1985 Nissan 300ZX Base Relay
Could this be why my Z31 wont engage when the key is turned over? If so where could I purchase missing relay?https://cimg0.ibsrv.net/gimg/www.zdr...9293b235b1.jpg
Originally Posted by Drewcole5150
(Post 346569)
they are a standard relay ,I am almost certain parts stores should have one you can swap the ascd & light relay |
The Inhibit isn't wired but the theft relay (starter) is not the same as any other relays in the car. i will try my local parts store in the AM. Thank you!
(Post 346572)
yes check the wiring diag. you can jump the contacts to try it |
Originally Posted by 86tcoupe
(Post 346577)
manual trans huh
(Post 346579)
Yes it is a Manual Trans. How would I go about jumping the contacts? Thanks
also see if you have the power to trigger the relay inhibit relay is you have to have the brake pedal firmly depressed before it will shift out of P man trans had a clutch swt. the same way checked mine ,yes 5 wire , mine has # 25230 C9961 part # |
