Z31 brakes
Old May 8, 2004 | 04:51 AM
S1j9m85's Avatar
Z31 brakes
Will brakes from an 87-89 z31 turbo or n/a fit on an 86 non-turbo
Old May 8, 2004 | 10:04 AM
JAMESZ's Avatar
You will have to switch out the hubs from the 87-89. But if you do this you can not only switch the brakes you could swap Z32 TT front brake calipers on.
Old May 8, 2004 | 03:59 PM
S1j9m85's Avatar
Do i have to switch the hubs even if the 86's hub studs are 5x114.3??
Old May 8, 2004 | 04:23 PM
JAMESZ's Avatar
Yes because it is a different set up on the 87-89.
Old May 8, 2004 | 10:16 PM
S1j9m85's Avatar
thanks for the info
Old May 8, 2004 | 10:32 PM
JAMESZ's Avatar
Your Welcome.
Old May 14, 2004 | 10:14 PM
S1j9m85's Avatar
Ok how about this? Will the front rotors fit of my car fit on the rear of my car without modification? just curious
Old May 15, 2004 | 12:16 AM
JAMESZ's Avatar
Err you will have caliper issues. The calipers fit around much smaller rotors in the rear putting the front back there wouldn't even fit. It won't work. If you want to see a brake set up me and johnZboy have exactly the same brakes here are mine http://dev.zdriver.com/gallery/showg...&what=&name=&= (at the bottom of the page) There are a few pictures of my brakes. They consist of KVR Carbon Fibre brake pads, Brembo Cross Drilled rotors, Goodridge Stainless steel braklines, and while I was at it I rebuilt all of the Calipers and put in some really good brake fluid after draining out all the old fluid. I decided not to go with the Z32 TT front calipers at the time since my tires seem to be at the max limit for my braking and the hub conversion. Let me say though this set up is crazy my Turbo can really brake now.
Old May 15, 2004 | 12:29 AM
S1j9m85's Avatar
Dude sorry about giving you a hard time i'm just looking for an easier and cheaper way to get better brakes.
Old May 15, 2004 | 10:48 AM
JAMESZ's Avatar
Haha its ok . Better to ask then to go try it and run into problems.
mikebuhrZ
Nov 24, 2008 12:29 AM
ddatsun
22
Nov 9, 2007 08:47 AM
Smittyz33
Mar 21, 2006 11:33 AM
Fast240Z
Other Cars
Dec 1, 2005 12:35 PM
Al Dukes
Oct 11, 2003 01:23 PM
