Help! (outer tie rod ends)
Old Jul 13, 2010 | 10:48 PM
anderlinedr's Avatar
I was recently in a crash in my z and it broke the outer tie rod on the right front. After a few hours of trying, my buddy and i could not get it off. There is a "nut" or hold point right past the boot, threads and a big (18 or 19mm) locknut on the rod. Does the rod go from the ball joint inside the boot or does it thread of after? any help would be greatly appreciated...
Old Jul 13, 2010 | 11:25 PM
hose everything off in PB blaster, then there is a surface cut into the center of the inner tie rod that you can stick a wrench on to keep it all from spinning. I would highly recommend making sure the frame is strait if it managed to break a tie rod though.
Old Jul 14, 2010 | 02:16 PM
do you know what size that nut is on the inner rod?
Old Jul 14, 2010 | 02:22 PM
Nope, I used a crescent wrench. It's most likely either a 12 or 14 though.
Old Jul 16, 2010 | 03:08 AM
i got it done.
dankfrye@charte
May 21, 2011 05:49 AM
entropy31
Jul 8, 2007 08:01 PM
nka04a
May 9, 2006 11:12 PM
mdharris11
Dec 22, 2004 01:38 PM
Paladin
May 31, 2003 06:51 PM
