speedometer problem
Old May 5, 2005 | 07:43 PM
86zxt(954)'s Avatar
its in the transmission almost at the end close to the diff.
Old May 5, 2005 | 10:07 PM
zcar300zx's Avatar
wait wait wait.....HAHAHAHAH youre killing me 86...hold on.....IN the transmission....CLOSE to the diff....first off the diff is at the REAR wheels...that big round thing in between the wheels under the car...the tranny is connected to the engine...round 6 feet away from the diff...IM NOT MAKING FUN OF YOU...IM HELPING 86...IM SORRY I REALLY AM NOT AN *** HOLE I DONT WANA come across that way but just make sure youre responding to a question properly...he is correct tho about the cable connecting to the tranny...its not a simple cable tho, its a connection to the tranny (an electrical connection) and inside the tranny is a little gear i believe...the faster it spins the higher the speed readout is...on z31.com they should have some good pics of this..check it out
Old May 5, 2005 | 10:40 PM
86zxt(954)'s Avatar
when i said close to the diff i meant the "cardan" at least i know where it is.... i worked on it before.... jejeje just to let you know.... and about the "but just make sure youre responding to a question properly..." the question was: " Where does it connect to??" there u go N/A buddi....
Old May 6, 2005 | 08:48 PM
zcar300zx's Avatar
i dont get it but ya ok...id have to look for the connection ive never dun tranny work and i dont look forward to doing so...but ya...its in the tranny shouldnt be more than one ore two connectors...should be one...
Old May 6, 2005 | 09:31 PM
entropy31's Avatar
The Cake Is A Lie!
wow, another one. this guy posted back in december, and thats the only post he has. i doubt he still checks here for the answer.
Old May 6, 2005 | 10:12 PM
zcar300zx's Avatar
man entropy..dammit im gunna start lookin at the date first lol
Old Jun 4, 2005 | 03:09 AM
SnooZn's Avatar
Just FYI...
Needle type z31 speedos from '86 backwards are mechanically / cable driven
Needle type z31 speedos from '87 forward are 'digitally' / electrically driven
ALL Digital speedo sending units are mechanically / cable driven, converting the signal to electric from the sending unit that's mounted by the passenger strut tower.
The '84-'86 speedos have the cable running from the tailshaft all the way into the rear of the instument cluster.
The main difference is the speedo pinion unit mounted in the tailshaft of the tranny.
For all cable units, digital or needle, the O-rings (there are two... one external and one internal) on the speedo pinion can get leaky, allowing gear oil to migrate up the cable and into the back of the speedo unit in the dash cluster.
That can gunk up the works and cause erratic readings.
That's one of the main reasons they switched over to an electical sending unit which stopped the contamination of the dash cluster. The cool thing is that the O-rings can be replaced and the speedo cleaned out.
You'll just have to pull the unit out to clean it.
Oh... and the tranny tailshaft and diff are not 6 feet apart seeing as the driveshaft is only about 3 feet long.
Don't worry though... you didn't come across as an *******. Just mis-informed.
PT
BlueKitsune
Aug 1, 2009 11:34 AM
audiofreak97
Jul 19, 2007 01:11 PM
flightforlife07
Jun 13, 2007 09:04 PM
dolcevita09
Jun 2, 2005 08:17 AM
