White smoke.
Old Apr 15, 2009 | 12:08 PM
marc z's Avatar
White smoke.
Ok guys here it go i have smoke coming out the tail pipe , also alittle sputter the radiator has a little oil in it i was thinking head gasket what do you guys think replace the head gasket or replace the engine.
Old Apr 15, 2009 | 12:23 PM
do a compression check and dont drive the car! if you (which you probably did) blew the head gasket you dont want to burn coolant it can cause some head aches. you'll probably have to get a new headgasket and it might be smart to get the head milled and new valve seals and a valve job done. maybe even the timing chain setup, or at least the tensioner, but not necessary. happy spending! (its less than a 300 dollar job with headwork i suggested so no big)
Old Apr 15, 2009 | 08:49 PM
marc z's Avatar
white smoke.
I did'nt drive it , It sit for while that i got a radiator put in that's it started . that for your info.
Old Apr 15, 2009 | 08:50 PM
marc z's Avatar
white smoke.
I did'nt drive it , It sit for while that i got a radiator put in that's it started . thank s for your info.
Old Apr 15, 2009 | 08:52 PM
marc z's Avatar
oh i have freind coming over in few days to run a check on i hope it works if not i may sell it.
bholm6
Apr 17, 2012 09:18 PM
tomas1329
Nov 9, 2009 12:37 AM
ZXT83
Sep 10, 2009 01:09 PM
c-murder
Oct 29, 2006 05:24 PM
Togish1
Sep 17, 2002 08:34 AM
