Where are all the nice wheels?
Old Feb 5, 2006 | 06:41 PM
RubberBerner's Avatar
Alright...i've been looking, and i've found some nice 15" set ups, some nice 16" set ups...but where are all the ZX's with 17's with a decent width and a flush offset (+15 or so)...and i don't wanna see any friggin spinners either lol. I understand the nostalgia look with the smaller wheels...and i love that look don't get me wrong, im just looking for new ideas.
Old Feb 5, 2006 | 06:51 PM
That's wierd... I've seen tons of 280zx's w/ 17" rims... they all use the honda wheel adapters. Seems to be the most popular rim size. Where you been lookin?
Old Feb 5, 2006 | 07:10 PM
s/cL3.0's Avatar
Bleach is my Hero
Whats the widest 17" anyone has on a Z?? I am getting some 5zigens soon
Old Feb 5, 2006 | 07:31 PM
nismo619's Avatar
i would like to see ebay items with pictures of the wheels spacers and a nice set of 4 rims 17" post them on hear ok ... nismo619
Old Feb 5, 2006 | 07:53 PM
nismo619's Avatar
http://cgi.ebay.com/ebaymotors/4X4-5...33991677QQrdZ1
are thouse the right ones z people ? 1 inch ? or 1.25 inch or 2 inch ? i need to know
http://cgi.ebay.com/ebaymotors/17-5Z...35493366QQrdZ1
how about these s/l 30 ? nice ZZZZZ huh ?
i was also told this rim is a direct bolt on ?
http://cgi.ebay.com/ebaymotors/O-E-1...35604162QQrdZ1
i know i dislike yellow unless u got a yellow Z car but hey i plan on buying these an re doing them to a color thats wayyyyyy better what do yall think ?
Old Feb 5, 2006 | 08:00 PM
wow... who needs Modern Motorsports now! They charge $240 for their spacers.
http://www.modern-motorsports.com/ca...products_id=11
Old Feb 5, 2006 | 09:12 PM
lww's Avatar
lww
Head Muckraker
Quality costs money. I would have a much higher level of confidence with Ross's wheel adapters than these generic ones.
Ross's have been proven at the race track and the last thing you want is your wheel to pass you on the highway at 80 mph...
Old Feb 5, 2006 | 10:07 PM
apollo's Avatar
Pro Pumpkin Carver
Seriously. I dont know about the quality of M.M. adaptors but i can tell you from experience . . .having your wheel pass you up is no fun. I used to drive a pro 1 ASDA series rail car for a local shop and the car sheered the lugs on the adaptors right off at about 70 going through some harsh dunes. ALL BAD. I can only imagine what would have happend had that been on the street or strip.
Old Feb 5, 2006 | 10:54 PM
nismo619's Avatar
so u would say not to use spacers? wheel hub adapters am i right ? i have looked at all my options and i think i will just go to 17 inch mustang 4 lug rims ill buy the ugly yellow ones on ebay nd repaint them etc to a color i like what do u think ? ill change out the center caps with the center caps from the new 2005 nissan altama rims, 350z rims etc what do you think ?
Old Feb 6, 2006 | 08:20 AM
To answer the original question, there are very few 17" and larger wheels that bolt right up and have +0 to +15 offset. If you find them, I'm sure they'll be around $500-600 each wheel, and the chances you find a set used are very slim.
Buy Modern Motorsports adaptors if you do buy adaptors. $40 extra for the set is nothing compared to the quality and confidence you'll have buying from an established Z related business.
But on that note, the adaptors are made to use wheels with +35 and +40 offset. Basically you have very little or no dish in your wheel. They are FWD type offsets. +15 will have that RWD deep dish look, especially on 7, 8, or wider wheels.
All late model RWD cars are 5-lug and are +30 offset, which is less than FWD by just a little. Even the RWD 240SX has a FWD offset...
If you do a 5-lug swap, you can use 350Z fitment wheels. (Supra, Mustang, Z32, ect) you'll get a decent lip on 8 inch wide wheels which fit fine. Also the selection of wheels will be huge in 17, 18, and 19 inch diameters.
I was actually planning to do a 5-lug swap to get a better wheel selection. At the time I came accross a used set of Simmons Racing wheels which are 3-piece custom wheels. They only come in 16" diameter. I wanted 17 or 18 but because these were zero offset and 4-lug I decided to just buy them. They have a tremendous deep dish and require no suspension mods to fit so I save some time and money there.
There are adaptors made that will bolt to your 4-lug hubs and give you 5-lugs with the 30mm spacing you need. This is the easiest 5-lug swap. I was going to go the route of using Z31 parts and redrilling some rotors to do my swap so I had a stronger setup but even then it would still require a pair of adaptors on the rear to space them out. The front would be brought outward on its own.
There really are a lot of options, but none of them involve just buying a 4-lug wheel from the store that bolts on and comes in 17, 18 inch diameter and +10 offset. The Simmons wheels are made to order from Austrailia and cost quite a bit. About $1500-2500 depending on width.
The 280ZX has very deep fender wells. You can easily fit 8 inch width wheels front and rear.
I have heard that the max width you can fit under the stock fender is 8.5" front and 10 inches rear. Both require about +10 and +12mm offset. At those widths, a 15" wheel will hit the trailing a-arm in the rear. Either a zero offset and flares would be required (pushing the wheel outward) or 16" and larger wheels will clear. I test fitted my 16x10 in the back and they clear. Right now I believe the offset is zero.
Old Feb 6, 2006 | 08:56 AM
Carl's Z's Avatar
Don't know if this will work, but saw these on zcar.com.....
Old Feb 6, 2006 | 09:07 AM
RodMoyes's Avatar
Doesn't post much...
??? Yeah!?!?!?!? Where are all the S130's with 17" wheels??????? .................................................. ........Rod.
Old Feb 6, 2006 | 09:18 AM
lww's Avatar
lww
Head Muckraker
Yes, they will. CenterLine continues to make their wheels in the Z car bolt and offset.
That's why I have two and a half sets of CenterLine wheels.
Call, tell them what you want and what car it's for and a week later they show up on your door step. No muss, no fuss.
Here's the set I use for the street:
I also have a set and a half of the fluted star's:
That's old school cool...
Old Feb 8, 2006 | 10:54 PM
I Like The Dish Look, Just My Opinion. Ross' Adapters Are Engineered, The Others Are Just Knock Offs. I Think Saftey Comes At A Price.
Old Feb 9, 2006 | 07:16 AM
Totally... it's the classic old school performance look.
Old Feb 9, 2006 | 07:50 AM
Old Feb 9, 2006 | 09:16 AM
s/cL3.0's Avatar
Bleach is my Hero
What is the widest 17 in. wheel any one has seen on a ZX?? Are the rear wheel wells the same as the 1st gens.??
Old Feb 9, 2006 | 09:29 AM
icice9's Avatar
Super Siver & Black Stud
ive seen 10.5s but they had to flare it out to get them to fit in the wheel well...
Old Feb 9, 2006 | 09:50 AM
The ZX has much wider rear wheel wells. I've seen only 8 inch wide front and rear on an S30 body. (and actually tuck with stock fenders) 8.5 front, 10 inch rear on a S130. Probably 17x10 in the back. +15 offset is about right. Maybe +10 I know, not much help....
Old Feb 9, 2006 | 07:57 PM
Imagine How The Car Would Handle With Rims That Wide With Some Nice Sticky Pirrelis Or Some Kuhmos. Yum, Yum.
Old Feb 10, 2006 | 06:13 PM
s/cL3.0's Avatar
Bleach is my Hero
I will live the dream for you.. 10" in the rear and 7.5 in the front
Old Feb 10, 2006 | 10:54 PM
Let Me Know If It Fits Stock Fenders And Bolt Pattern And Where You Got The Wheels, Then Ill Live My Own Dream!!
83turbo280zx
Mar 3, 2013 10:58 AM
SoCal-s130
20
Sep 16, 2006 09:21 PM
unique280
Mar 4, 2006 01:00 AM
Z-man240
Oct 14, 2004 04:10 PM
twinhairdryers
Jun 21, 2003 06:24 PM
