Turn signal light question
Old Apr 22, 2014 | 03:04 PM
ohsemix's Avatar
Ok so i checked every wire under the steering column that goes to the turn signal and none get any current my hazards dint work at a point but i cleaned the inside and they work now. But my turn signal flasher and the switch dont get current. I checked my fuse box switched my fuses but the turn signal fuse is the only one not getting current even after switching them. I checked the wiring diagram but it doesnt show the fuse box.So i would like to know were the fuse wires get current from and i would also like to know the color for the turn signal fuse wire coming out of the fuse box.
Old Apr 22, 2014 | 04:01 PM
PredatorZ's Avatar
Fusible Links
When all your fuses appear good, then you need to check your fusible Links, they are in a box near your battery, your FSM will show you exactly where. Fusible Links are made of a lower gauge wire than the circuit they are protecting, when you experience a high current on a circuit the Link will melt. The plastic cover on the wire is designed to not melt when the wire does, so it may appear intact, best to check continuity with a meter or test light. here is a link to what you may need, not all local parts stores carry the Fusible Links.
Motorsport! Fusible Links & Covers - The Z Store, Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
Old Apr 23, 2014 | 10:36 AM
The turn signals won't work if the hazards switch isn't COMPLETELY off. Check the hazards switch...
Old Apr 23, 2014 | 01:28 PM
ohsemix's Avatar
i have checked all the links and relays in the engine bay with a test light about a week ago but that wasn't it all of them work.Nismo what do you mean the hazards need to be completely off i disconnected the hazard switch because it got in my way but im not sure if that thats completely off
Old Apr 23, 2014 | 04:42 PM
ohsemix's Avatar
ok i fixed it i cleaned the grounds in the engine bay and i forgot that the hazards need to be connected for the turn signals to work but when i connected the hazards to checked them the signal lights worked so i guess it was the ground on the block that we painted and was also dirty
Old Apr 28, 2014 | 01:47 PM
ohsemix's Avatar
well they stopped working again lol what could have caused it to stop?
Old Apr 28, 2014 | 03:04 PM
borini63's Avatar
Wigggllle the Hazard switch back and forth slowly until you get signal!!See at what point your signal works in the hazard switch and then leave it a lone,don't miss with it.It's a 30+ years switch.....
Old May 1, 2014 | 04:32 PM
ohsemix's Avatar
lol ill try it its so delicate
Old May 1, 2014 | 05:43 PM
PredatorZ's Avatar
worn out
Those switches are the source of a lot of problems, the contacts become worn and corroded and stuff stops working. Taking them apart and cleaning will help.
Old May 3, 2014 | 03:35 PM
ohsemix's Avatar
hey predator z your first post may be the issue after all i didnt notice till now but one of the fusible links is toast so ill buy one soon
Old Oct 8, 2014 | 02:18 PM
ohsemix's Avatar
so i made a link out of regular wire and it burnt up again. Its the ACC fusible anyone know what might cause this i dont have power anywhere after it burnt out
Old Oct 13, 2014 | 12:27 PM
Using normal wire in place of a fusible link is a quick way to see your car go up in flames... I'm surprised only that replacement wire burnt up. Must have been a small gauge?
Look in the FSM and check all components that are powered by that fusible link.
plainwhiteZ
May 1, 2012 02:04 PM
gdcat51
Jun 27, 2009 12:15 AM
JDsmash
Aug 12, 2005 11:30 AM
Perry
Oct 17, 2004 07:09 PM
OrangeZ32
Jun 19, 2004 03:35 PM
