Toothed wheel on crank pulley?
Old Sep 2, 2012 | 05:17 PM
LemonHead's Avatar
The toothed wheel on my crank pulley has come loose and is wobbling around in there. On my other car (not a Z), this toothed wheel is for the ignition system and doesn't run well if it can't get a good read on the position. However, with the Z, the car seems to run just fine with it even flapping around. What is this wheel for? Thanks in advance.
Old Sep 2, 2012 | 07:03 PM
Only the 1981 280ZX Turbo had a toothed plate on the crank pulley for the crank angle sensor. So you either have an 81 turbo, or a crank pulley from an 81T (you didn't say what model / year your car is).
Old Sep 2, 2012 | 07:14 PM
LemonHead's Avatar
Thanks NismoPick. That's interesting. The car is an 80 or 81, I don't know honestly, but is most certainly NOT a turbo. Can't imagine why somebody would have swapped the turbo pulley on there. Guess I'll just try to tack weld the thing back on so it doesn't flap around.
Old Sep 2, 2012 | 08:25 PM
Or take it off... unless you know how to balance it after you weld it.
Old Sep 2, 2012 | 11:20 PM
If it's not a turbo you don't have a CAS on the harmonic balancer. Pics...
Old Sep 3, 2012 | 08:45 AM
LemonHead's Avatar
Will see if I can get a photo and post it up.
goodoldZdays
FS: 300ZX (90-96)
Mar 12, 2009 10:36 AM
sholez
Oct 7, 2006 06:21 PM
HybridS130
Feb 6, 2006 08:36 AM
81 Black L28E
Oct 4, 2005 09:51 PM
lance75_280z
Sep 11, 2003 06:28 PM
