took my Z to the track.
15.7 @ 90mph is quick for stock... are you sure it's completely STOCK?
Factory stock rating was 17sec+.
Factory stock rating was 17sec+. ...
intake
msd coil
8mm accel wires
ngk spark plugs
airtrack fuel pump
turbo injecters
turbo fuel rail
turbo fuel pressure regulater
took some crap off, ex. A/C, cruse control, charcol box and some other stuff.
also replaced all the hoes that make the motor look like ***.... only to find out that i dont need most of them on at all... so im looking into getting a custom intake manifold, and a stage 2 cam from msa, aswell as some fatter rubber in the rear
no it didnt... and it came with a bosh fuel pump airtrack < bosh. still turbo injecters wont change the power... its still getting the stock fuel flow just a bigger injecter
cant post my time slip but i do have it
dial in .00
reaction .60
60 ft 2.32
330 ft 6.61
1/8 et 10.23
1/8 mph 69.03
1/4 et 15.84 (thought it was 15.74)
1/4 mph 88.67
if i had a scaner i would scan it but dont, if ya think im pulling this outta my *** thats fine just cuz you think it didnt happen doesnt mean it didnt
dial in .00
reaction .60
60 ft 2.32
330 ft 6.61
1/8 et 10.23
1/8 mph 69.03
1/4 mph 88.67
I see a "15.84 @ 87.67mph" result... Where is your 15.74 @ 90mph?
Why did you install the turbo injectors if they flow just like the n/a's?
Well.... I hate to say it, but his numbers are pretty legit.
I have about the same "mods" (if that's what you want to call them) and I went from 17.76 @ 82mph to 15.32 @ 91mph. 1st run was at about 500ft. and the latter was at over 5,000ft. ...and that was with my bad suspension. I need to run again to see what kind of times I'm pulling since I'm damn near sea level. ...just for fun, of course. This ain't no drag car.
intake
msd blaster 2 coil
"mostly" stock L28e
bald tires
better pic of tires
this is where all the power comes from....
bald tires
