Tips for Smog
Old Feb 15, 2008 | 05:36 PM
JoeGasm's Avatar
Tips for Smog
I live in California, and I was wonderin' if you guys had any tips on how to pass? I drive an '83 280ZX with T-tops (N/A), if that helps. Also, what kind of oil does it use? Or which do you recommend as the best?
Old Feb 15, 2008 | 05:49 PM
Low timing, properly flowing cat & fuel injectors... same things for any car. 10w-30 is a common weight oil.
Did your Z just fail emissions?
Old Feb 15, 2008 | 07:28 PM
run a liter of methyl hydrate, inflate your tires to max psi, new cat, or good shape, run 6 deg. ignition timing. unplug, or disable #5 injector. cant loose then, it works, just try it!! i got it down to a science, and my motor is nasty without the changes.
Old Feb 15, 2008 | 10:29 PM
BackHouseZ's Avatar
smog
What is 6 deg.
Old Feb 15, 2008 | 10:38 PM
Originally Posted by BackHouseZ
What is 6 deg.
Is that a Jeopardy answer? Like Shady said, 6 degrees of ignition timing.
Old Feb 15, 2008 | 11:49 PM
Niku-Sama's Avatar
eff good grammar
dont forget to replace the muffler bearing and bring some cash to bribe the guy
Old Feb 15, 2008 | 11:52 PM
Does that go along side the flux capacitor?
Old Feb 16, 2008 | 12:09 AM
Niku-Sama's Avatar
eff good grammar
no this is the flux capacitor
its in the engine compartment and hooks up between your EGR valve and the rest of the vaccum system, theres also a hose on the bottom that hooks to the exhaust
Old Feb 16, 2008 | 10:46 AM
His 83 won't have that....
And there's no such thing as a muffler bearing. It's just called an EGR valve.
Old Feb 16, 2008 | 01:08 PM
JoeGasm's Avatar
Yeah...
I'm a total beginner when it comes to car parts
I can figure out the catalytic converter, fuel injectors, and inflating the tires-
But a liter of methyl hydrate? Where? And how do I change the ignition timing? I can ask my dad about the 5th injector
10W-30 oil? Thanks you guys, I'm gonna get it smogged soon.
Old Feb 16, 2008 | 05:29 PM
In the gas tank.
With a timing gun.
10W-30 oil?
Yep.
Old Feb 16, 2008 | 06:50 PM
JoeGasm's Avatar
Aight, methyl hydrate in the tank. With or without gasoline? Also, what about like higher octane gasoline? Think that'll help?
Old Feb 16, 2008 | 06:57 PM
With. This isn't rocket science.
High octane fuel = higher emissions (not good when trying to pass emissions).
Just do what we suggest. And again I ask (because you didn't answer me when I asked the first time): Did the car just fail emissions? Why are you so worried that it won't pass?
Old Feb 16, 2008 | 07:26 PM
Niku-Sama's Avatar
eff good grammar
i dont care is his 83 doesent have that and i hope your not telling me mufflet bearings dont exist.
either way i posted a pic of that thinky up there and no one told me what it is or what it does so i said i was going to call it a flux capicitor, obviously since i am not going back or foreward in time its of no use to me unless some one can explain it to me.
Old Feb 16, 2008 | 08:01 PM
Dude... where's your HAYNES manual?!??!?
Page 141-142 of the 280zx manual, page 232 of the 240z-280z manual:
It's a BPT valve
Old Feb 16, 2008 | 08:30 PM
flightforlife07's Avatar
nismo hate to rain on your parade haha http://kalecoauto.com/index.php?main...products_id=10
and actually there is toyota designed one to allow the exhaust pipes to flex on some of there newer cars because of the tight bends...
Old Feb 16, 2008 | 09:02 PM
Niku-Sama's Avatar
eff good grammar
i love that site
Old Feb 16, 2008 | 09:22 PM
Not sure how that relates to a 280zx EGR system... but cool. Muffler bearing does not = BPT valve.
Old Feb 16, 2008 | 10:42 PM
JoeGasm's Avatar
I haven't smogged it yet, but I'm low on the cash flow so I want to make sure it gets it the first time, you know? Thanks for the help.
Old Feb 16, 2008 | 11:24 PM
Niku-Sama's Avatar
eff good grammar
the hell does the BPT valve do?
no i dont have my manuals they've gone MIA as they normally do when i need them
Old Feb 17, 2008 | 11:01 AM
It controls the vacuum pressure to the EGR. Google my friend...
Old Feb 17, 2008 | 12:39 PM
they charge you to do emmisions? in IL when they used to call me when i had OBD1 the testing was free.
Old Feb 17, 2008 | 03:06 PM
ah yes but now the government wants there cut, up here its 24dolla per test, get expensive fast, thats why i cheat to pass!! for a late model car up here its 48 dolla, and you get tested every 2 years. and all they do is plug in the obd port and tell you its good. the 5th injector really helps i found, but i got a hefty number of modifications, but it did help on all my customers z cars, and they were stock. you just gotta make sure that if they are gonna do an under hood check you try and hide the injector being un pluged, or put a connection in it that you can unplug and hide.
Old Feb 17, 2008 | 04:43 PM
Niku-Sama's Avatar
eff good grammar
24 per test? how much do they charge for tags?
here its $10 for the test ~$60 for the tags
Old Feb 18, 2008 | 11:40 AM
lww's Avatar
lww
Head Muckraker
You guys crack me up.
First, if you're in Cali, get a "pre-test". Basically, you pay to have them smog check it, but, if it's WAY over the limit, you don't get screwed by being labeled a "gross polluter" and it'll give you an idea of what's not working right.
Yes, you have to pay for it twice, but it's worth it to avoid possible nightmares later.
If you want to take a shot at it and try to get it to pass the first time, check your catalytic converter and make sure it isn't plugged or empty. Then, like Shady suggested, unplug or block the contact where it connects to the injector on the #5 cylinder counting from the front (by the radiator) to the back (by the windshield). Make sure it isn't obvious and there's no dangling wires or the smog tech may get suspicious.
This will reduce the amount of fuel going into the system and increase the RATIO of unburnt air coming out the exhaust, diluting the emissions and making it look better than it really is. The L6 motor has enough torque that you can barely tell when one cylinder is missing, there are no "engine" warning lights and the average joe smog tester won't know what to do when he can't find an OBD port anyway. As long as the sniffer test passes, he'll send you on your way with a passing grade.
However, I always try to pass my emissions tests with legitimate numbers since that is a great indicator that the car is actually running properly and efficiently.
