Suggestions for a aftermarket fuel pump?
Old Feb 2, 2005 | 06:23 PM
Heat Rave R's Avatar
Sooner or later, I'm going to get an engine swap for my '82 NA 280ZX. I want to be getting an aftermarket fuel pump that will support 300-400hp and would like some suggestions on what kind to get. I've heard of Aeromotive and Walbro pumps. I had always thought it was an in-tank pump, but I think I see it right behind the rear-right wheel. Is there a particular kind of pump (in terms of flow-rate and fitment) I need to look for? Also, anyone know some places that have good prices on em?
Old Feb 2, 2005 | 08:14 PM
lifegrddude's Avatar
Externally Wastegated
Walbro fuel pumps, one of them is close to a direct bolt in. Plenty of people on Hybrid use it. I think it's the GSL392 or something like that. Flows 255lph so it's good enough. If you check with Summit racing or Jegs, I'm pretty sure you'll find the pump. It's ~150 bucks.
Old Feb 2, 2005 | 08:17 PM
Skully's Avatar
yuppers i gota walbro 255lph fuel pump make sure you get the INLINE not INTANK one...its not in operation yet since m engine is out..but thats what i bought...
255lph walbro and aeromotive FPR
Old Mar 15, 2005 | 02:48 PM
fairladyVT's Avatar
Old Porche pumps work and they put out a ton of fuel pressure. YOu can even blosk off the return line and add larger lines if your injectors are strong enough to shut under the pressure.
305zx
Sep 4, 2011 06:32 PM
sameerb1
Mar 20, 2011 05:21 AM
MylesBlaq
Jul 3, 2010 02:41 PM
ern
Oct 20, 2006 07:01 AM
zryde
May 6, 2003 08:46 PM
