Strange digital dash problem
Old Dec 27, 2015 | 10:02 AM
bkmontreal's Avatar
Dear specialists ,
I would need your kind help refer to a problem with my digital dash of my 280zx´turbo
After changing my battery , I found that the speedometer on the digital dash began to act strangly, cycling though 1-9 untill I reached a cruising speed of what I guessed is around 55mph, when which the dash reads a steady 11mph.
The car starts fine and all other gauges are still correct,except water temparature background lighting which is since the beginning sometimes working sometimes not, as best as I can tell; it also drives exactly the same--no lost power or anything out of the ordinary. Fuses and fuse links are fine and poles of te battery were/are fixed properly
I'm mildly perplexed as for what to do now .
I read something about evtl. problems with speedometer-sensor connections but have no idea where to look for . Is it under the hood ? at which place ?
any help, pics or ideas would be highly appreciate
thanks
Bernard
Old Dec 28, 2015 | 07:14 AM
The speed sensor is on the back of the speedometer / main gauge cluster. Have you downloaded the FSM? The 83 FSM has an entire section for the digital gauges.
Click: XenonZcar.com S130 Factory Service manuals
Old Dec 28, 2015 | 09:22 AM
bkmontreal's Avatar
Thanks for the hint NismoPick FSM I have downloaded already but unfortunately was not able to find any solutions to my problem ������
marcello129
May 12, 2005 04:17 AM
zxlori
May 2, 2004 06:30 PM
austin
Sep 5, 2002 08:33 AM
skelator
Aug 25, 2002 12:14 AM
Phalkin
May 16, 2002 11:01 AM
