Startup Problem?
Old Mar 9, 2009 | 05:30 PM
KingDatsun1's Avatar
Startup Problem?
The Z died on me 3 days ago, I started it up and the rpm would go to about 1000, then decrease until it died. I could get it to start, I just had to rev the motor for a few seconds, then it would be fine. most of the time it works perfectly!
what gives?
(yes I searched)
Old Mar 9, 2009 | 05:34 PM
The basic answers:
Check timing, TPS, fuel pressure, AFM, CHTS, all sensor connections....
Old Mar 9, 2009 | 06:45 PM
i'd check vacuum to.
Old Mar 23, 2009 | 03:37 PM
IRideRome's Avatar
My NA 1981 280zx is having the same problem as you kingdatsun, did you find a solution?
I just pulled my AFM and it's perfect inside, no grime. I've already replaced the vacuum tubes.
Time to check everything else I suppose...
Joel2125
Aug 25, 2012 03:22 AM
sidd
Jun 8, 2011 03:27 PM
ultimatepoghero
Feb 2, 2010 02:18 PM
zeppelinboy
May 5, 2007 03:21 PM
GenHawk
Jan 14, 2005 10:36 AM
