Speedometer Broken (inside tranny)
Old Apr 2, 2008 | 12:58 PM
2.8.0.Z.X's Avatar
Hey all,
My speedo cable is hooked into the transmission properly but doesn't want to turn when I drive. I can turn the cable by hand while it is still connected to the tranny.
If whatever drives the speedo in the transmission has gone out how much $$ am I looking at for replacement parts?
I just bought a new cable for it so I know the cable is still in one piece.
Thanks.
Old Apr 2, 2008 | 01:37 PM
#1... How do you know it's not the speedo that doesn't work?
#2... You can take the speedo cog out of the tranny & inspect it. Remove the cable from where it mounts to the tranny... you will see a 10mm bolt holding the cog in place... remove it... pull out cog. They are prolly super cheap from a junk yard (if not free). Just pay attention to the year of the car the tranny came from, & the color of the cog gear.
Old Apr 2, 2008 | 02:30 PM
2.8.0.Z.X's Avatar
#1: The cable doesn't spin on the speedo end when the car is driving. (I pulled it out from the back of the speedo and watched it)
#2: I'm pulling the cog out now -- The local junkyards don't have any 280zx trannys though
Thanks for the info.
Old Apr 2, 2008 | 02:58 PM
2.8.0.Z.X's Avatar
Just pulled it and the gear looks kinda stripped. Is this probably due to old age or to something else in the tranny?
Update: I stuck my finger in the speedo hole in the tranny and I could feel a gear on a rod that could easily be moved to both ends. There seemed to be a washer on the rod to the rear of the gear. Why would a washer be moving up and down this rod? I might be wrong but it did feel like a washer.
studio110
Jun 9, 2012 08:24 PM
BC240Z
May 30, 2007 10:11 AM
phrozen209
Aug 19, 2004 11:41 PM
Airpilot16
Dec 19, 2003 01:46 PM
