speaker sizes
Old May 22, 2003 | 03:27 PM
futureZowner's Avatar
speaker sizes
Hey,
I recently purchased a '79 280ZX 2-seater and would like to update the stereo a little bit. I need to know what size speakers fit in the dash for a '79 model and what size speakers fit nicely (no cutting or anything) in the speaker mounts behind the seats? Thanks in advance for the info.
Old May 22, 2003 | 03:50 PM
icice9's Avatar
Super Siver & Black Stud
im not sure but i think its a 4" speaker
Old May 22, 2003 | 09:25 PM
Skully's Avatar
yup 4"
Old May 22, 2003 | 11:13 PM
rear speakers....?
ok ok, 4" speakers in the front....but what size fits best in the mounts behind the seats? thanks.
Old May 23, 2003 | 12:23 AM
icice9's Avatar
those are 4" too
Old Jul 21, 2012 | 08:24 AM
Male's Avatar
So 4" for the 2 in the dash?
Old Jul 21, 2012 | 10:14 AM
evandubya's Avatar
Primer Grey FTW!
I'm pretty sure the ones behind the seat are 6".
Old Jul 21, 2012 | 10:23 AM
4" for the dash and the stock rears are 5 1/4" but 6 1/2" will fit without cutting - just need to change the screw holes.
Old Jul 21, 2012 | 12:29 PM
Male's Avatar
On a 79? Mine look like 4"
Old Jul 21, 2012 | 02:25 PM
4" in the front - rears are stock 5 1/4 but 6 1/2 will fit
Old Jul 21, 2012 | 06:18 PM
Male's Avatar
one question how the hell do you take this one off?
Old Jul 21, 2012 | 07:04 PM
evandubya's Avatar
Primer Grey FTW!
You have to pull the whole dash out!!!!
Old Jul 22, 2012 | 08:00 AM
Male's Avatar
Realy?!
Old Jul 22, 2012 | 08:34 AM
evandubya's Avatar
Primer Grey FTW!
Yep, the screws are on the under side and all the ducting and heater box is in the way.
Old Jul 22, 2012 | 01:20 PM
Male's Avatar
Well that sucks and the other on is just remove the glove box right?
Old Jul 22, 2012 | 01:56 PM
evandubya's Avatar
Primer Grey FTW!
I just looked at my 79 dash. If you are rather dexterous, you might be able to reach the center speaker with a small no. 2 phillips screwdriver if you, pull the glove box, remove the center gauges and the ducting, but it would be quite a stretch. Good luck.
Old Jul 22, 2012 | 03:05 PM
Haha good luck!
Pull the dash and replace all the foam in your ducting and wash it all in the sink while you're in there. Makes a big difference for your air flow from the vents.
Old Jul 23, 2012 | 12:45 AM
duckyz's Avatar
You can get some tin snips and make cut outs for 6x9s behind the seats. Trying to figure out where to fit some 6.5" in the front...
Old Jul 23, 2012 | 02:27 AM
1980zx's Avatar
get some shallow 4" speakers and make some custom kick panels for the floorboard. Its way easier then removing the dash. Or what you could do is just put some 1" tweeters on the front kick panels and two 6x9 in boxes in the back. Thats what I did with 2 10" subs- Sounds great
Old Jul 23, 2012 | 06:51 AM
Male's Avatar
Ok when taking out the dash is there any way posible that I can put the streeing wheel rong because that's my biggest consern not trying to go of topic
Old Jul 23, 2012 | 10:40 AM
evandubya's Avatar
Primer Grey FTW!
Just make sure the tires are straight, take off steering wheel, don't turn tires, put steering wheel back on when finished.
Old Jul 26, 2012 | 01:54 PM
Male's Avatar
well mine are 4" all around if you want to keep the oem speaker covers for the rear and you could fit 61/2 without cutting behind the seats?
alfradrod
Apr 15, 2006 09:03 AM
DavidWann
Dec 2, 2003 03:21 PM
ex247
May 8, 2002 04:32 AM
Craig_Paterson
Mar 29, 2002 05:45 AM
81Datsun280ZX
Feb 19, 2002 10:18 AM
