So, I thought I'd be cool and install a K&N Cone Filter...
Old Jun 7, 2007 | 07:53 PM
crowthma's Avatar
Talking So, I thought I'd be cool and install a K&N Cone Filter...
because the stock box looks pretty cheesy and you're supposed to getter better air flow and blah blah blah. But, I noticed that I've got another hose down there that used to pipe into the bottom of the stock air cleaner box. Anyone know what should I do with it?
Attached Thumbnails So, I thought I'd be cool and install a K&N Cone Filter...-dscf1084.jpg   So, I thought I'd be cool and install a K&N Cone Filter...-dscf1085.jpg
Old Jun 7, 2007 | 08:27 PM
turboboost's Avatar
Just went and checked on mine, and it doesn't have it.
Old Jun 7, 2007 | 08:56 PM
crowthma's Avatar
Hmm, I guess it's called an Air Induction System
And it is unique to models produced in 1980. Hayne's says it draws fresh air directly into the exhaust manifold to help burn hydrocarbons before they are expelled as exhaust. So, I guess filtering it is not essential since the worst case scenario would be getting dirt in my exhaust. But having dirt in my exhaust probably won't provide any great benefits. Do people think I should port this into the air cleaner line or just put a seperate filter on it?
Old Jun 7, 2007 | 09:02 PM
turboboost's Avatar
You probably don't even need a filter on it. If you really want one, just go buy a mini one and be done with it.
Old Jun 8, 2007 | 03:03 AM
thxone's Avatar
My friend has a 1980 2+2...he just put one of those little oil breather filters on it...sounds cool cause it growls a little bit...his car runs fine with it disconnected and the little filter on it.
Old Jun 8, 2007 | 06:30 AM
apollo's Avatar
Pro Pumpkin Carver
Wow, ive never seen that. So many little things here and there you pick up on these cars the more time you spend around'm. Shoot, since ive done the swap all sorts of new things have started working. Like now i just found out my Z has door lock illumination. Saw it for the 1st time the other night. its all bright neon green lookin. And its timed. Kinda kewl.
Old Jun 8, 2007 | 07:14 AM
turboboost's Avatar
Did you notice any difference in power?
Old Jun 8, 2007 | 07:40 AM
RodMoyes's Avatar
Doesn't post much...
Just leave it open... Mines been open for 4 years.
The little box that it goes into has a filter in it. Just remove that filter every few months and clean it out.
BTW. It's called the "Air Induction Valve" and is ONLY on 1980 Model year cars WITHOUT California Emmisions equipment.
Rod.
Old Jun 8, 2007 | 05:25 PM
crowthma's Avatar
The new filter sounds awesome
I'm not sure if it's just psychological; I didn't dyno it before and after. But, it feels a lot more powerful anyway. And I've managed so shave some weight off my tires since installation.
Old Jun 8, 2007 | 05:29 PM
crowthma's Avatar
I just ordered a little K&N to match my main air filter
Rod.
I didn't see this until just now and didn't realize there was an inline filter before the reed valve. Oh well, it'll look cool and probably make cleaning a little easier.
Sweets
May 20, 2009 10:30 AM
nismo619
Sep 15, 2008 11:35 AM
Darkmann
13
Jan 27, 2008 06:22 PM
Turbo86
Oct 20, 2006 10:57 AM
nka04a
Sep 2, 2005 03:25 PM
